thanks so much, do you know how I find the DNS server address? I've managed to get the rest I think ?
no... lol .. how do I do that 🙂
The DNS server should be 192.168.1.254
do you know if you can use the Devolo 500 adapter with a Devolo Dlan Highspeed Ethernet II?
thats what I've got.. I couldn't not find another adapter to go with the Highspeed Ethernet II online.
If the adapters are not connecting to each other, then that would be a problem. Have you tried plugging in a laptop into the end of the connection, instead of the TV, and see if the laptop works?
Powerline adapters are usually quite fussy about what they will work with, so you may have to use a totally different pair, like the BT Broadband extender.
http://www.shop.bt.com/learn-more/bt-branded-products-and-services/bt-broadband-extenders-12523.html
ok I have found the answer.. the blue adapters that I have from Devolo are not compatable with the white one I have now bought! ops... looks like a return to organise.. thanks very much for all the help.
