Message 1 of 10
Connecting smart to to BTHub6
Just got BTHub6. Now trying to connect smart TV as device. Get as far as finding the wireless network, enter the wireless password, but then I t says press the button on your AP. Now stuck - where/what is this button please?
9 REPLIES 9
Message 2 of 10
Re: Connecting smart to to BTHub6
there is no such button on any hone hub is you have manually entered the password all you should need to do is save it on your tv
Message 3 of 10
Turn off smart setup in hub and I would split the networks - move switch from on to off
Message 4 of 10
Thanks. That's what I thought, but it keeps giving me the same message! Bit frustrating!
Message 5 of 10
Thanks. I chose assisted set up as it was the only one that seemed to work... I don't see the on off option.
Message 6 of 10
If you go to hub manager then advanced settings then wireless then toggle separate bands to 'on'
Message 7 of 10
WPS button on left hand edge of Hub6???
Message 8 of 10
You need to enter 192.168.1.254 into the address bar then administration password from hub card then go to advanced then wireless then switch separate to on
Message 9 of 10
Thanks - I will try that in the morning!
Message 10 of 10
brilliant - thank you - it worked!
