Message 1 of 3
Connecting to PPPOE using 3rd Party Routers
All had been running smoothly for years until I rebooted my pfsense box 2 days ago. It's (was) attached directly to the ONT and configured to login to PPPOE  using U/N "[email protected]" and p/w "bt" and never had an issue.
Then I rebooted by pfsense box - wan down.
Sometime over the previous 19 days it would appear BT have changed something their end and I can no longer connect. I've had to put the Smart Hub 2 back in and daisy chain to pfsense via DHCP. Not really ideal for me - it should be an unnecessary hop.
I've also tried with openwrt and opnsense and neither of those machines can connect anymore either.
I note the smart hub (which admittedly I don't know very well) says its connected to vlan36 now:
ppp0:The WAN DHCPv6 Client Process has successfully been launched on Vlan 36
Which I tried tagging that vlan on the switch for my opnsense test box (router on a stick setup) by assigning vlan36 to the wan interface but to no avail.
Anyone out there know what's going on or had similar issues?
2 REPLIES 2
Message 2 of 3
Re: Connecting to PPPOE using 3rd Party Routers
Nothing has changed with the PPPoE login, if it had all the BT hubs would stop working.
It would seem to be a bit of a coincidence if BT suddenly decided to change something at the exact moment you rebooted your pfsense box!!
Message 3 of 3
I didn't say that.
I was wondering if it had changed sometime over the previous 19 days while I was already connected. I presumed extant connections wouldn't get kicked off.
I'd understood the ONT stripped any vlan tagging off. That vlan 36 normal?
