So, I currently live in an extension off the main property and before getting a 2nd line installed i would use the main house broadband (home hub 5) but connection would always drop out and i believed it to be due to the thickness of the wall seperating the extension from main house which is considerably BIG! where we would only get the tip end of the wifi. I finally decided it was time we ordered our own broadband (home hub 6) an just before christmas 4 engineer appointments later we had a 2nd line into the extension and were connected but the nightmare disconnects still happen and "usually" between 10pm & 1am but can happen at anypoint these are just the most consistent timings. Now the disconnects usually blink orange for maybe 10-30 seconds and then comes back blue but can happen between 1 or 10+ times before it'll settle other times have been for upto 45 minutes and have gone green or purple on the hub. I recently reported this to BT and an engineer came out this week on Tuesday and did tests on the line and found a fault 69m away with noise on the line and got a cherry picker out same day and replaced the drop cable, I was hopeful this was the end of the disconnects but everyday since it has dropped out exactly the same with no difference and i've heard of problems with the homehub 5 + 6 but is it too coincidental that both of our routers are naff? I check the router logs immediately after disconnects but too be honest i'm not techy enough where i can determine where it's telling me the problem so i'll put it below incase it helps.
Thanks in advanced for any help & replies.
22:06:51, 18 Jan.:HTTP UserAdmin login from 192.168.1.73 successfully
22:06:50, 18 Jan. ppp1:TR69 connectivity to (pbthdm.bt.mo) has been closed
22:06:48, 18 Jan. ppp1:TR69 connectivity to (pbthdm.bt.mo) has been initiated
22:06:48, 18 Jan.ppp1:TR69 receiving InformResponse message
22:06:47, 18 Jan.ppp1:TR69 event found : 4 VALUE CHANGE
22:06:46, 18 Jan.ppp1:TR69 sending Inform message
22:06:44, 18 Jan.ppp1:TR69 event found : 4 VALUE CHANGE:
22:06:43, 18 Jan.ppp1:TR69 sending Inform message
22:06:41, 18 Jan.ppp1:TR69 creating new session with ACS
22:06:24, 18 Jan.:This Rule has been applied successfully: [id:147, InternalClient: 192.168.1.72, External Ports: (55192,0), Internal Ports: (55192,0), Protocol: UDP]
22:06:24, 18 Jan.:Adding port mapping rule by System
22:06:23, 18 Jan.:Updating port mapping rule (147) by System
22:06:21, 18 Jan.:This Rule has been applied successfully: [id:146, InternalClient: 192.168.1.72, External Ports: (3074,0), Internal Ports: (3074,0), Protocol: UDP]
22:06:21, 18 Jan.:Adding port mapping rule by System
22:06:21, 18 Jan.:Updating port mapping rule (146) by System
22:06:20, 18 Jan.:The LAN DHCP Server is active
22:06:17, 18 Jan.:The LAN DHCP Server is inactive
22:06:17, 18 Jan.: Deleting port mapping rule (145) by System
22:06:17, 18 Jan.:Updating port mapping rule (145) by System
22:06:17, 18 Jan.BR_LAN:The DHCP options that are offered by the device (id:5): DiscoverOptions: 53,55 | DiscoverOption55: 1,3,15,6 | RequestOptions: 53,54,50,51,55 | RequestOption55: 1,3,15,6 | HostName: | VendorId:
22:06:14, 18 Jan.: DHCP Confirmation of Request
22:06:07, 18 Jan.wl0:IGMP join received for group 239.0.0.250 on interface wl0
22:06:07, 18 Jan.wl0:A WiFi device <C8:02:10:C1:A1:F3> has successfully connected to SSID (Device/WiFi/SSIDs/SSID[WL_PRIV5G])
22:06:07, 18 Jan.wl0:IGMP group 239.0.0.250 on interface wl0 started by 192.168.1.68
22:06:07, 18 Jan.wl0:IGMP group 239.0.0.250 on interface wl0 by 192.168.1.68 requested
22:06:07, 18 Jan.:This Rule has been applied successfully: [id:145, InternalClient: 192.168.1.72, External Ports: (3074,0), Internal Ports: (3074,0), Protocol: UDP]
22:06:07, 18 Jan.:Adding port mapping rule by System
22:06:07, 18 Jan.:Updating port mapping rule (145) by System
22:05:35, 18 Jan.wl1: Device <84:38:38:75:2E:A0> was disconnected on SSID (Device/WiFi/SSIDs/SSID[WL_PRIV2G])
22:05:35, 18 Jan.wl0: Device <4C:66:41:46:11:8C> was disconnected on SSID (Device/WiFi/SSIDs/SSID[WL_PRIV5G])
22:05:35, 18 Jan.wl1:A WiFi device <84:38:38:75:2E:A0> has successfully connected to SSID (Device/WiFi/SSIDs/SSID[WL_PRIV2G])
22:05:35, 18 Jan.wl0: Device <C8:02:10:C1:A1:F3> was disconnected on SSID (Device/WiFi/SSIDs/SSID[WL_PRIV5G])
22:05:35, 18 Jan.wl0: IGMP group 239.0.0.250 on interface wl0 ended by 192.168.1.68
22:05:35, 18 Jan.wl0: Device <84:38:38:75:2E:A0> was disconnected on SSID (Device/WiFi/SSIDs/SSID[WL_PRIV5G])
22:05:16, 18 Jan.wl1: Device <B4:AE:2B:91:35:05> was disconnected on SSID (Device/WiFi/SSIDs/SSID[WL_PRIV2G])
22:05:09, 18 Jan.ppp1: The WAN DHCPv6 Client Process has successfully been launched on Vlan 36
22:05:09, 18 Jan.: Deleting port mapping rule (144) by System
22:05:09, 18 Jan.: Updating port mapping rule (144) by System
22:05:05, 18 Jan.BR_LAN:The LAN DHCPv6 Server is active
22:05:05, 18 Jan.BR_LAN:LAN Router Advertisement Setting Updated : M_flag = 0, O_flag = 1
22:05:05, 18 Jan.BR_LAN:The LAN DHCPv6 Server is inactive
22:05:02, 18 Jan.BR_LAN:LAN Router Advertisement Setting Updated : M_flag = 0, O_flag = 1
22:05:02, 18 Jan.BR_LAN:The LAN DHCPv6 Server is active
22:05:02, 18 Jan.ppp1:The WAN DHCPv6 Client Process has successfully been launched on Vlan 36
22:05:02, 18 Jan.BR_LAN: Allocated prefix = fdaa:bbcc:ddee::/64 (valid time = 4293967296 / preferred time = 4293967296)
22:05:02, 18 Jan.BR_LAN: Allocated prefix = 2a00:23c4:430a:8f00::/64 (valid time = 2026291200 / preferred time = 2026291200)
22:05:02, 18 Jan.BR_LAN: Allocated address = 2a00:23c4:430a:8f00:5a90:43ff:fec3:80e7 (valid time = 2026291200 / preferred time = 2026291200)
22:05:02, 18 Jan.ppp1: Allocated prefix = 2a00:23c4:430a:8f01::/64 (valid time = 2026291200 / preferred time = 2026291200)
22:05:02, 18 Jan.ppp1: Allocated prefix = 2a00:23c4:430a:8f00::/56 (valid time = 2026291200 / preferred time = 2026291200)
22:05:02, 18 Jan.ppp1: Allocated address = 2a00:23c4:430a:8f01:5a90:43ff:fec3:80e5 (valid time = 2026291200 / preferred time = 2026291200)
22:05:02, 18 Jan.BR_LAN:The LAN DHCPv6 Server is inactive
22:05:02, 18 Jan.ppp1:WAN DHCPv6 Mode : Statefull
22:05:01, 18 Jan.BR_LAN:The LAN DHCPv6 Server is active
22:05:01, 18 Jan.BR_LAN: Allocated prefix = fdaa:bbcc:ddee::/64 (valid time = 4293967296 / preferred time = 4293967296)
22:05:01, 18 Jan.BR_LAN: Allocated prefix = 2a00:23c4:430a:8f00::/64 (valid time = 2026291200 / preferred time = 2026291200)
22:05:01, 18 Jan.BR_LAN: Allocated address = 2a00:23c4:430a:8f00:5a90:43ff:fec3:80e7 (valid time = 2026291200 / preferred time = 2026291200)
22:05:01, 18 Jan.ppp1: Allocated prefix = 2a00:23c4:430a:8f01::/64 (valid time = 2026291200 / preferred time = 2026291200)
22:05:01, 18 Jan.ppp1: Allocated prefix = 2a00:23c4:430a:8f00::/56 (valid time = 2026291200 / preferred time = 2026291200)
22:05:01, 18 Jan.ppp1: Allocated address = 2a00:23c4:430a:8f01:5a90:43ff:fec3:80e5 (valid time = 2026291200 / preferred time = 2026291200)
22:05:01, 18 Jan.ppp1:The WAN DHCPv6 Client Process has successfully been launched on Vlan 36
22:05:01, 18 Jan.BR_LAN:The LAN DHCPv6 Server is inactive
22:05:01, 18 Jan.BR_LAN: Revoked prefix = 2a00:23c4:430a:8f00::/64 (valid time = 2026291200 / preferred time = 2026291200)
22:05:01, 18 Jan.ppp1:WAN DHCPv6 Mode : Statefull
22:05:00, 18 Jan.ppp1: Allocated prefix = 2a00:23c4:430a:8f00::/56 (valid time = 2026291200 / preferred time = 2026291200)
22:05:00, 18 Jan.wl0:IGMP join received for group 239.0.0.250 on interface wl0
22:04:58, 18 Jan.ppp1:The WAN DHCPv6 Client Process has successfully been launched on Vlan 36
22:04:58, 18 Jan.ppp1:WAN DHCPv6 Mode : Statefull
22:04:58, 18 Jan.ppp1:WAN Router Discovery Setting Updated : M_flag = 1, O_flag = 0
22:04:55, 18 Jan.ppp1:New DYN ROUTE is added [81.139.56.100/32 gw ]
22:04:55, 18 Jan.ppp1:New DYN ROUTE is added [81.139.57.100/32 gw ]
22:04:55, 18 Jan.ppp1: PPP: PPP INFO 81.139.57.100,81.139.56.100
22:04:55, 18 Jan.wl0:IGMP join received for group 239.0.0.250 on interface wl0
22:04:51, 18 Jan.ppp1:The WAN DHCPv6 Client Process has successfully been terminated on Vlan 36
22:04:51, 18 Jan.ppp1:The WAN DHCPv6 Client Process has successfully been launched on Vlan 36
22:04:51, 18 Jan.:WAN: SENSING AUTO VDSL
22:04:51, 18 Jan.ppp1: PPP: PPP INFO
22:04:48, 18 Jan.ppp: PPP: IPCP_NAK
22:04:48, 18 Jan.ppp: PPP: CHAP_SUCCESS
22:04:47, 18 Jan.ppp: PPP: CHAP_RESPONSE
22:04:47, 18 Jan.ppp: PPP: LCP_GOOD_ACK
22:04:47, 18 Jan.ppp: PPP: LCP_REQUEST
22:04:47, 18 Jan.: PPPoE error: timeout
22:04:39, 18 Jan.:HTTP UserBasic login from 192.168.1.73 successfully
Try quiet line test. Dial 17070 option 2. Should be quiet and best with corded phone
if hh6 then go to advanced settings then technical log admin and post stats
Also currenlty there are only 5 devices that are connected to the hub:
- Xbox One X (Ethernet)
- Desktop PC (Ethernet)
- Xbox One (Wifi)
-Samsung S7 Edge
-Samsung S5
Thanks for the quick responce also i don't use a phone on my line but when the engineers came out there was noise but once they replaced the drop cable from the house to the box situated on the 2nd pole from the house they confirmed it had gone.
This link explains why you need a landline phone. http://forumhelp.dyndns.info/broadband/adsl/needphone.html
Ok, I accept that but the mainhouse and their router use a phone and their dropouts still occur similar to ours so i'm going to assume this probably isn't the cause.
Sounds more like interference from something in the house - electrical - central heating or similar
Nothing else is on in either side of the household between the usual disconnect times of 10pm & 1am as everyone is normally asleep at these times except myself. Heating comes on 6am, midday & 6pm.
