Message 1 of 21
Connection Drops and Possibly Odd Router events?!
Hi,
After having a connection that never dropped out, we seem to be losing connection at least once a day now.
The router lights do not go out, but all of the devices in the house (2 laptops and an xbox) lose connection at the same time.
I've been searching around online, but haven't found anything very useful yet.
I've had a look at our router stats (but they mean nothing to me!) Can anyone help me out here, do these look okay? We seem to have rather a lot of FECs errors, but from what I've read this isn't that concerning (and I've also read that the particularly large figure is possibly a bug).
ADSL line status
Connection information
Line stateConnected
Connection time0 days, 2:46:33
Downstream18,005 Kbps
Upstream1,181 Kbps
ADSL settings
VPI/VCI0/38
TypePPPoA
ModulationITU-T G.992.5
Latency typeInterleaved
Noise margin (Down/Up)3.3 dB / 6.0 dB
Line attenuation (Down/Up)18.0 dB / 9.6 dB
Output power (Down/Up)0.0 dBm / 12.6 dBm
Loss of Framing (Local)0
Loss of Signal (Local)0
Loss of Power (Local)0
FEC Errors (Down/Up)569453 / 4294967232
CRC Errors (Down/Up)0 / N/A
HEC Errors (Down/Up)N/A / 0
Error Seconds (Local)0
I've also been looking at the Event Log (which I've never looked at until today - below). It seems a bit odd that there is lots for today, but then nothing since the 1st of January - can this be right?
There also some entries which seem to keep repeating - those  regarding upnp 'addportmapping' and those regarding firewall icmp check. Should I be worried about these entries?
I'd be really grateful if anyone has any explanation for these? It'd be very helpful to know whether I have a problem or not??? Thank you for any help anyone can give....
Tina
22:37:39  26 MarIDS proto parser : tcp null port (1 of 1) : 88.214.207.38 109.156.54.97 0040 TCP 0->10070 [..AR..] seq 0 ack 1070966620 win 0
22:36:19  26 MarUPnP action 'AddPortMapping' from ip=192.168.1.66 (Success)
22:36:17  26 MarUPnP action 'DeletePortMapping' from ip=192.168.1.66 (No such entry in array)
22:36:17  26 MarUPnP action 'AddPortMapping' from ip=192.168.1.66 (Success)
22:36:14  26 MarUPnP action 'DeletePortMapping' from ip=192.168.1.66 (No such entry in array)
22:35:17  26 MarLOGIN User admin logged in on [HTTP] (from 192.168.1.65)
22:35:12  26 MarLOGIN User Basic logged in on [HTTP] (from 192.168.1.65)
22:27:48  26 MarFIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 186.213.185.33 Dst ip: 109.156.54.97 Type: Destination Unreachable Code: Port Unreacheable
22:17:35  26 MarLOGIN User admin logged in on [HTTP] (from 192.168.1.65)
22:17:17  26 MarLOGIN User Basic logged in on [HTTP] (from 192.168.1.65)
22:16:13  26 MarUPnP action 'AddPortMapping' from ip=192.168.1.66 (Success)
22:16:11  26 MarUPnP action 'DeletePortMapping' from ip=192.168.1.66 (No such entry in array)
22:16:10  26 MarUPnP action 'AddPortMapping' from ip=192.168.1.66 (Success)
22:16:08  26 MarUPnP action 'DeletePortMapping' from ip=192.168.1.66 (No such entry in array)
22:14:25  26 MarFIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 109.74.221.50 Dst ip: 109.156.54.97 Type: Destination Unreachable Code: Host Unreacheable
22:13:09  26 MarFIREWALL icmp check (1 of 2): Protocol: ICMP Src ip: 151.21.24.86 Dst ip: 109.156.54.97 Type: Destination Unreachable Code: Port Unreacheable
21:57:11  26 MarFIREWALL icmp check (1 of 2): Protocol: ICMP Src ip: 76.108.16.198 Dst ip: 109.156.54.97 Type: Destination Unreachable Code: Host Unreacheable
21:56:07  26 MarUPnP action 'AddPortMapping' from ip=192.168.1.66 (Success)
21:56:05  26 MarUPnP action 'AddPortMapping' from ip=192.168.1.66 (Success)
21:54:03  26 MarUPnP action 'AddPortMapping' from ip=192.168.1.64 (Success)
21:51:38  26 MarSNTP Synchronised to server: 213.123.20.170
21:36:08  26 MarIDS scan parser : tcp port scan: 65.254.218.140 scanned at least 10 ports at 109.156.54.97. (1 of 1) : 65.254.218.140 109.156.54.97 0040 TCP 80->55499 [..AR..] seq 61733015 ack 1047957272 win 0
21:33:13  26 MarLOGIN User admin logged in on [HTTP] (from 192.168.1.65)
21:33:07  26 MarLOGIN User Basic logged in on [HTTP] (from 192.168.1.65)
21:15:15  26 MarUPnP action 'AddPortMapping' from ip=192.168.1.66 (Success)
21:15:12  26 MarUPnP action 'DeletePortMapping' from ip=192.168.1.66 (No such entry in array)
21:15:12  26 MarUPnP action 'AddPortMapping' from ip=192.168.1.66 (Success)
21:15:10  26 MarUPnP action 'DeletePortMapping' from ip=192.168.1.66 (No such entry in array)
21:12:41  26 MarFIREWALL icmp check (1 of 2): Protocol: ICMP Src ip: 74.94.123.146 Dst ip: 109.156.54.97 Type: Destination Unreachable Code: Port Unreacheable
20:57:45  26 MarFIREWALL icmp check (1 of 2): Protocol: ICMP Src ip: 70.189.97.237 Dst ip: 109.156.54.97 Type: Destination Unreachable Code: Host Unreacheable
20:51:38  26 MarSNTP Synchronised again to server: 213.123.26.170
20:42:27  26 MarFIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 212.120.245.161 Dst ip: 109.156.54.97 Type: Destination Unreachable Code: Host Unreacheable
20:28:26  26 MarFIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 184.57.170.249 Dst ip: 109.156.54.97 Type: Destination Unreachable Code: Host Unreacheable
20:18:57  26 MarLOGIN User admin logged in on [HTTP] (from 192.168.1.65)
20:16:36  26 MarCONFIGURATION saved by TR69
20:16:11  26 Mar[CWMP] Connection Request NOT ALLOWED.
20:16:09  26 MarLOGIN User Basic logged in on [HTTP] (from 192.168.1.65)
20:12:17  26 MarFIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 141.255.67.110 Dst ip: 109.156.54.97 Type: Destination Unreachable Code: Port Unreacheable
19:58:23  26 MarFIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 141.255.67.110 Dst ip: 109.156.54.97 Type: Destination Unreachable Code: Port Unreacheable
19:56:21  26 MarFIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 176.31.211.130 Dst ip: 109.156.54.97 Type: Destination Unreachable Code: Port Unreacheable
19:55:00  26 MarUPnP action 'AddPortMapping' from ip=192.168.1.66 (Success)
19:54:59  26 MarUPnP action 'DeletePortMapping' from ip=192.168.1.66 (No such entry in array)
19:54:58  26 MarUPnP action 'AddPortMapping' from ip=192.168.1.66 (Success)
19:54:56  26 MarUPnP action 'DeletePortMapping' from ip=192.168.1.66 (No such entry in array)
19:51:38  26 MarSNTP Synchronised to server: 213.123.26.170
19:51:38  26 MarSNTP Systemtime update: time setting 01:04:00 > new time setting: 19:51:38
00:03:30   1 JanUPnP action 'AddPortMapping' from ip=192.168.1.64 (Success)
00:03:28   1 JanUPnP action 'AddPortMapping' from ip=192.168.1.64 (Success)
00:02:27   1 JanLOGIN User admin logged in on [HTTP] (from 192.168.1.65)
00:02:15   1 JanLOGIN User Basic logged in on [HTTP] (from 192.168.1.65)
00:02:08   1 JanCONFIGURATION saved by TR69
00:01:33   1 JanPPP link up (Internet) [109.156.54.97]
00:01:33   1 JanPPP CHAP Chap receive success : authentication ok
00:01:33   1 JanPPP CHAP Receive challenge (rhost = bras-red7.gi-b)
00:01:28   1 JanxDSL linestate up (ITU-T G.992.5; downstream: 18005 kbit/s, upstream: 1181 kbit/s; output Power Down: 21.1 dBm, Up: 12.6 dBm; line Attenuation Down: 18.0 dB, Up: 9.6 dB; snr Margin Down: 6.7 dB, Up: 2.9 dB)
00:01:25   1 Janusbmgr: USB device isn't matched the configuration
00:01:25   1 Janusbmgr: try /etc/usbmgr/class/module
00:01:25   1 Janusbmgr: try /etc/usbmgr/class/09/module
00:01:25   1 Janusbmgr: try /etc/usbmgr/class/09/00/module
00:01:25   1 Janusbmgr: try /etc/usbmgr/class/09/00/00/module
00:01:25   1 Janusbmgr: class:0x9 subclass:0x0 protocol:0x0
00:01:25   1 Janusbmgr: buffer line: remove T
00:01:04   1 JanxDSL linestate down
00:00:54   1 JanDHCS server up
00:00:54   1 JanFIREWALL event (1 of 1): deleted rules
00:00:49   1 JanFIREWALL level changed to Standard.
00:00:44   1 JanWIRELESS automatic channel selection done (channel = 10)
00:00:41   1 JanFIREWALL event (1 of 1): modified rules
00:00:41   1 JanFIREWALL event (1 of 1): created rules
00:00:30   1 JanWIRELESS interface turned on.
00:00:28   1 Janusbmgr: start 0.4.8
00:00:19   1 Jan
KERNEL Cold restart
20 REPLIES 20
Message 2 of 21
Re: Connection Drops and Possibly Odd Router events?!
Hi how are you connecting the xbox and laptops by wireless or ethernet cable
Message 3 of 21
don't worry about the 1st of January that seems to appear an all HH3's i have seen
Message 4 of 21
They all connect via wireless. Thanks for any help you can give.
Tina
Message 5 of 21
Ooops, mine is a Home Hub 2 by the way
Message 6 of 21
ok your hub is showing only 2 hours plus connection have you restarted it for any reason
Message 7 of 21
have seen it there as well dont worry about it
Message 8 of 21
John,
We lost the connection earlier this evening, and even though the lights were all still on on the Router, the only way to regain our connection seemed to be turning the router off and on (we did this at the plug, i'm not sure this is what we're meant to do!).
Are the events in my event log worrying at all? I'm scared by them!
Tina
Message 9 of 21
the router log is nothing to worry about
Message 10 of 21
Could you try and explain to me what the port ones and the firewall ones mean to me? Just so I have some understanding?
Any idea why our disconnections might be occuring - once a day isn't that inconvenient but it shouldn't be like that obviously!
Tina
