Jorvikwarrior
Message 1 of 1
Connection Going Mad...
I have had Infinity 2 installed Sept 2012, and for the first 6 weeks or so it was great around 50Mbps thruput, then I had a fault and my connection has not be right from then on. The engineer came added a smaller micro filter behind the master socket. My speed has now dropped about 15meg below what I was getting prior and my IP profile is going mad. From the 10th jan my profile has changed 14 times that I am aware of.
I contacted the mods, who said because my line is above the fault threshold that nothing can be done... but added to this the really naff congestion on a night and bad routing it really is starting to drive me crazy
This is a daily sample of my IP Profile from 10/1 and sometimes it can change as many as three times in a day...
34.89
40.65
40.65
40.65
40.1
40.1
45.31
45.31
40.1
40.1
41.6
32.86
37.26
37.5
42.21
42.21
42.21
42.96
30.3
42.02
42.02
41.79
Anyone got any ideas how to get around this as the profile is above the fault threshold?
I test using a wired connection, I am now connecting using an alternative router (apple airport) and have tried althernative ethernet cables to see if it made any difference...
