Travelstar
Message 1 of 7
Connection Issues during initial install period
Hello! Hopefully someone will be able to help me.
I recently switched to BT Broadband from another provider, however during the initial 14 days when you are meant to leave your router on I ended up having to switch it off quite a bit as my gas mains were being replaced (the gas mains are right next to my BT master socket) which meant a equiptment had to be turned off, moved, etc. Consequently my line has not adjusted correctly which is something I would like to resolve.
Initially my line was connecting using fastpath, but now appears to just stay interleaved and ideally I would like to stay on fastpath as it greatly improves connecting to my office's internet conferencing facilities which I use a lot. Any ideas on how I can get BT to re-stablise my line?
Here are my line stats for reference:
Line state:Connected
Connection time:0 days, 01:09:09
Downstream:16.96 Mbps
Upstream:1.17 Mbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Modulation:G.992.5 Annex A
Latency type:Interleaved
Noise margin (Down/Up):6.0 dB / 6.3 dB
Line attenuation (Down/Up):17.8 dB / 8.9 dB
Output power (Down/Up):16.6 dBm / 12.3 dBm
FEC Events (Down/Up):60934 / 0
CRC Events (Down/Up):67 / 0
Loss of Framing (Local/Remote):0 / 0
Loss of Signal (Local/Remote):0 / 0
Loss of Power (Local/Remote):0 / 0
HEC Events (Down/Up):1382 / 0
Error Seconds (Local/Remote):56 / 0
6 REPLIES 6
gouledw
Recognised Expert
Message 2 of 7
Re: Connection Issues during initial install period
Hi Travelstar,
If you have finished the training period, then to get you're Latency setting changed you will have to contact the mods, you can do that by following this link: http://bt.custhelp.com/app/contact_email/c/4951
Travelstar
Message 3 of 7
Thank you for your help. Mods have now been contacted.
Travelstar
Message 4 of 7
Does anyone know the usual turnaround time for the mods?
Message 5 of 7
Hi yes they will contact you personally by email or phone. Normally within 3 days
Travelstar
Message 6 of 7
They have indeed now contacted me and the rep/mod has updated my profile.
Thanks all for your help.
Message 7 of 7
Hi travelstar glad all is ok now if you ever need any furtherhelp pleasepostback as someone here will be glad to hrlelp
