sharenngraham
Message 1 of 10
Connection Keeps Dropping
Hello,
Over the past few days, maybe even over the last week my connection has been dropping out, each time my internet gets slower. I am hoping that a mod could reset my SnR, as my connection was running at 22Mb with no connection drops.
Currently my SnR is 15dB and I'm on a Fastpath profile.
1. Product name: BT Home Hub
2. Serial number: +068340+NQ60701387
3. Firmware version: Software version 4.7.5.1.83.8.130.1.26.1.1 (Type A) Last updated Unknown
4. Board version: BT Hub 4A
5. ADSL uptime: 0 days, 00:27:49
6. Bandwidth: 1179 / 15896
7. Data sent/received: 12.7 MB / 295.1 MB
8. Broadband username: bthomehub@btbroadband.com
9. BT Wi-fi: Yes
10. 2.4 GHz Wireless network/SSID: BTHub4-9RM5
11. 2.4 GHz Wireless connections: Enabled (802.11 b/g/n (up to 144 Mb/s))
12. 2.4 GHz Wireless security: WPA and WPA2
13. 2.4 GHz Wireless channel: Automatic (Smart Wireless)
14. 5 GHz Wireless network/SSID: BTHub4-9RM5
15. 5 GHz Wireless connections: Enabled (802.11 a/n (up to 300 Mb/s))
16. 5 GHz Wireless security: WPA2
17. 5 GHz Wireless channel: Automatic (Smart Wireless)
18. Firewall: Default
19. MAC Address: 90:72:82:86:e0:a0
20. VPI/VCI: 0 / 38
21. Modulation: G.992.5 Annex A
22. Latency type: Fast
23. Software variant: -
24. Boot loader: -
ADSL Line Status
Connection Information
Line state: Connected
Connection time: 0 days, 00:28:21
Downstream: 15.52 Mbps
Upstream: 1.152 Mbps
9 REPLIES 9
imjolly
Message 2 of 10
Re: Connection Keeps Dropping
If your router is dropping connection then resetting your noise margin manually is pointless as you will be back in same position within a few days at most. You need to fix the problem of hub dropping connection and then hub should recover speed automatically
Are you using test socket with a new filter to eliminate your setup and internal wiring
Try quit line test dial 17070 option 2 should be quit and best with corded phone
sharenngraham
Message 3 of 10
The router hasn't left the test socket since we put the router in, I've tried a new micro filter and the line is quiet as it should be. I did notice today that there was an Openreach van at an underground duct, I have no idea what they were doing though. The connection was fine for so long but I did have to restart the hub myself as Twitch streams were constantly buffering, until I restarted the router. It dropped not long after that and I assumed it would fix itself but it hasn't.
imjolly
Message 4 of 10
Are there any problems here. http://usertools.plus.net/exchanges/mso.php
http://usertools.plus.net/exchanges/?
http://btbusiness.custhelp.com/app/service_status
http://bt.custhelp.com/app/answers/detail/a_id/15036
http://community.plus.net/exchange-information/
Your noise margin will start to drop with speed increasing but your need a stable connection 24/7 for 3/5 days.  Will probably recover in a few stages but stable connection with no resets/drops in connection is very important
sharenngraham
Message 5 of 10
There is no problems at all with my exchange.
Curious as to what Openreach were doing then.
Hopefully a mod can reset my SnR and then see what happens.
Is there any way for me to restart the connection if it becomes stale again and I get buffering on Twitch?
imjolly
Message 6 of 10
Unless you have a stable connection for at least 3+ days your will not get noise margin reset. You need to find cause of drops in connection. If you can post your router stats showing a stable connection with 3+ days connection time then we can see if mods will help reset noise margin but if not stable then reset is pointless
john46
Message 7 of 10
to start with please stop all manual resets of your router that is not helping your problem a manual reset is pointless as the noise margin will increase within hours unless the connection is stable
sharenngraham
Message 8 of 10
Can a mod please reset my SnR?
My connection was solid for a week, I kept expecting it to reset and give me a faster speed but it hasn't until tonight and there was no change in my speed.
00:15:40, 16 Jun.( 93.790000) DSL noise margin: 5.90 dB upstream, 15.00 dB downstream
5. ADSL uptime: 0 days, 00:05:05
6. Bandwidth: 1191 / 15768
7. Data sent/received: 0.6 MB / 6.8 MB
9. BT Wi-fi: Yes
20. VPI/VCI: 0 / 38
24. Boot loader: -
imjolly
Message 9 of 10
if you had a stable connection for a week it's a pity you didn'y post the stats and ask for mods to reset noise margin  see if they will doo it now even though only 5min connection  if there is an underlying problem causing drops in conenction then you will be back to high noise margin and lower speed in no time
mods will post here
After completing the email NOT PM then you join a queue of other customers waiting for mod help. The mods will get back to you in 1/2 working days either by phone or email
DanielS
Moderator
Moderator
Message 10 of 10
Hi @sharenngraham,
We can certainly look into it for you to see what needs to be done.
You can get in touch by clicking on "DanielS" and then on contact the mods.
DanielS
