My Infinity 1 connection is usually rock solid and upload speed consistently in the mid to high 20s, and has been for several years. About a month ago the village lost broadband for a day and since then the speed has been a bit variable. BT Wholesale test seems to indicate a potential issue with the speed bar appearing red, even though the speed is roughly the same as it's always been. Should I be worried? Is there a fault? Test was done with a direct connection from Mac to Openreach modem. Would welcome any guidance please. Thanks!
Solved! Go to Solution.
