psycho_eric
Message 1 of 4
Connection Speed - is there an issue?
My Infinity 1 connection is usually rock solid and upload speed consistently in the mid to high 20s, and has been for several years. About a month ago the village lost broadband for a day and since then the speed has been a bit variable. BT Wholesale test seems to indicate a potential issue with the speed bar appearing red, even though the speed is roughly the same as it's always been. Should I be worried? Is there a fault? Test was done with a direct connection from Mac to Openreach modem. Would welcome any guidance please. Thanks!
3 REPLIES 3
Webby
Message 2 of 4
Re: Connection Speed - is there an issue?
Ignore the red bar.
Speed seems fine.
psycho_eric
Message 3 of 4
Thanks Webby. Should I be concerned that the speed is (just) below the "acceptable range" for the connection?
Webby
Message 4 of 4
No, that download speed is pretty much the most you'll get on that connection speed.
It's a reporting error on that test.
