leighjones123
Message 1 of 2
Connection Unstable / Speed Fluctuating
Hi 🙂 Wondering if anyone can help...
I've had Infinity installed since mid October, and up until now it's been great. No noticable connection problems or any issues at all with speed.
This week however, that's changed.
It's as if the connection is "dropping out" intermittently.. It's hard to describe, but I'll be browsing the web, and all of a sudden - I'll just start getting "page cannot be displayed" errors.. I have to keep refreshing a few times and then it'll kick back in by itself. I think the "0.07" downspeed result shows this below
I also notice that my speeds are fluctuating massively.. I've ran a number of speed tests to prove this, both on my laptop and iPhone (to try and prove that it's not one machine related)
Here's the data from my iPhone:
Here's the data from my home hub:
1. Product Name: HomeHub5
2. Serial number: +076286+1521022367
3. Firmware version: v0.07.05.0A13-BT (Type B) Last updated 24/11/2015
4. Board version: 01
5. VDSL uptime: 0 days, 08:52:53
6. Data Rate: 9999 / 40000
7. Maximum Data Rate: 24621 / 81942
8. Noise Margin: 22.6 / 20.0
9. Line Attenuation: 21.5 / 18.0
10. Signal Attenuation: 0.0 / 0.0
11. Data sent/received: 138.6 MB / 603.9 MB
12. Broadband username: bthomehub@btbroadband.com
13. BT Wi-fi: Yes
14. 2.4GHz wireless network/SSID: BTHub5-ZG6F
15. 2.4GHz wireless connections: Enabled (802.11 b/g/n (up to 144 Mb/s))
16. 2.4GHz wireless security: WPA2 Only (Recommended)
17. 2.4GHz wireless channel: Automatic (Smart Wireless)
18. 5GHz wireless network/SSID: BTHub5-ZG6F
19. 5GHz wireless connections: Enabled (802.11 a/n/ac (up to 1300 Mb/s))
20. 5GHz wireless security: WPA2 Only (Recommended)
21. 5GHz wireless channel: Automatic (Smart Wireless)
22. Firewall: Default
23. MAC Address: 5c:dc:96:5c:12:de
24. Software variant: -
25. Boot loader: 0.5.0-BT (Tue Jun 17 18:52:56 2014)
Is there anything I can do to fix this?
Many thanks,
Leigh
1 REPLY 1
imjolly
Message 2 of 2
Re: Connection Unstable / Speed Fluctuating
your stats show you are on max speed for infinity 1
are you using wireless as devices are phone and laptop?  if so
have you turned of smart setup
Turn Off smart setup
have you split the networks
Split the networks
