Help us improve our customer experience. We are very keen to get your thoughts on some of the ideas we are exploring. Please take a few minutes to complete this short survey,
Hi all
I have an issue that I could do with some advice with.
This has happened a few times over the years but this time I am stumped.
My homehub is constantly dropping connection, sometimes a few times in an hour and sometimes after 3 to 6 hours etc.
I have had a steady DL sync speed of around 10.9 since the exchange was upgraded over a year ago. The connection dropouts began on Xmas eve with over 50 in a day. These connections have continued to drop since although not at this rate. The phone line also went of on a couple of occasions.
My DL and UL sync speed had dropped a lot since. The UL has since recovered.
I have spoke to the call centre, with the usual advice given. I have changed micro filters and even unplugged phones but this has made no difference. I did have a HH4 but replaced it with my old HH2 on Indias advice, made no difference.
The line with the noise test seems fine.
I understand that with a constant connection my BRAS profile will increase to how it was, the issue is that I cant get the steady connection needed.
PLEASE HELP< ITS DRIVING ME CRAZY !!
Here are my latest line stats.
ADSL line status
Line state | Connected |
Connection time | 0 days, 0:18:51 |
Downstream | 6,653 Kbps |
Upstream | 1,163 Kbps |
VPI/VCI | 0/38 |
Type | PPPoA |
Modulation | ITU-T G.992.5 |
Latency type | Interleaved |
Noise margin (Down/Up) | 6.4 dB / 6.3 dB |
Line attenuation (Down/Up) | 34.5 dB / 18.1 dB |
Output power (Down/Up) | 0.0 dBm / 12.9 dBm |
Loss of Framing (Local) | 232 |
Loss of Signal (Local) | 76 |
Loss of Power (Local) | 0 |
FEC Errors (Down/Up) | 1682 / 4294967205 |
CRC Errors (Down/Up) | 0 / N/A |
HEC Errors (Down/Up) | N/A / 0 |
Error Seconds (Local) | 464 |
Are you connected to the test socket?
Hi
Not at the moment but I have tried that and it was the same.
Nothing has changed in the house, so i find it hard to understand what else could be the problem.
1- micro filters changed
2- HH4 replaced with HH2
3- phones disconnected.
Still no change.
No factors that i can think of to have an intermitent effect.
What are your views regarding my stats ?
Any help will save what is left of my sanity !!!
Could a sky box connecetd to the socket affect it ? The set up has been the same for years ?
