thanks, looks like they are resetting???
<script type="text/javascript" language="JavaScript" src="x-javascript/wz_tooltip.js"></script>
Notes: If your download speed lies in this range then your connection seems to be working fine. |
Notes: The Download Speed is the average rate that was achieved during this test. |
Notes: Your line is configured to the maximum rate that it can support or at your chosen fixed rate, this is known as the line rate and would be viewed through your CPE software or in your router configuration. Your IP profile is always less than the line rate and is normal on any network. The Assured rate figure quoted will always be smaller than the assured rate profile. This is because in order for the throughput to reach its destination, it requires an overhead which explains the difference between the two. |
Notes: Your line is configured to the maximum rate that it can support or at your chosen fixed rate, this is known as the line rate and would be viewed through your CPE software or in your outer configuration. Your IP profile is always less than the line rate and is normal on any network. |
<script type="text/javascript"></script> <script type="text/javascript" language="JavaScript" src="x-javascript/wz_tooltip.js"></script> <script type="text/javascript" language="JavaScript" src="x-javascript/continue.js"></script>
