Haitoman1
Message 11 of 12
Re: Connection dropping at regular 7 minute intervals
Yes, the IP address changes every time. Almost like a different computer is scanning my network every 7 - 8 minutes.
raymie67
Expert
Message 12 of 12
If your I address is changing then you are losing PPP0A logon, why you can't see that in your logs I don't know but this is exactly the same thing I had once upon a time.
Have you tried stopping all download activity and seeing if that helps?
either way you need to contact the mods to get this raised it will not be something you can fix I suspect (unless you have set your router to not stay online (ie not to keep alive the link).
If my post was helpful then please click on the Ratings star on the left-hand side If the the reply answers your question fully then please select ’Mark as Accepted Solution’
