evanowen
Message 11 of 27
Re: Connection dropping for over a year I'm fed up now
I am connected by wire, what does wireless have to do with anything?
john46
Message 12 of 27
on some occasions the problem is wireless based and not there when using a wired connection just trying to get the maximum information from you to try and help with your problem
evanowen
Message 13 of 27
My PC doesn't have a wifi card, it is connected to the router with a cable and the router is connected to the master socket with another cable, both of which are less than 2m long and both of which I have swapped on numerous occasions to appease the poor souls in India.
It is exasperating...
john46
Message 14 of 27
Have you tried the quiet line test dial 17070 option 2 you should hear no noise if you can hear noise then it needs reporting to BT faults on 151 with no mention of broadband in the call also have you tried connecting the hub to the test socket using a new filter
evanowen
Message 15 of 27
I have tried everything, BT helplines are so useless I have learned the diagnostics off pat.
john46
Message 16 of 27
have you got any noise on the phone line
evanowen
Message 17 of 27
No noise at all
evanowen
Message 18 of 27
My socket is a MK3, it takes the Cat5 cable direct.
john46
Message 19 of 27
in that case you need an engineer visit to resolve your problem
evanowen
Message 20 of 27
Thanks. Had two here and still no joy.
In my opinion this is a downhill slide for broadband as we know it, too many people doing too much on a tiny fibre strand and a thin piece of copper or worse still aluminium.
Without major investment we will end up with 56K. But I am no engineer.
