Message 111 of 121
Re: Connection dropping out
you have still got noise issues with your connection your modulation has dropped from adsl2+ to adsl2
i would suggest you contact the forum mods and ask them to reset your noise margin to 6db as the 3db you are on now is to low for your line you will lose a little connection speed but there will be less errors reducing the disconnection problems
lobsterboy1
Message 112 of 121
Hi, One of the mods Dean reset my noise margin on the 19/03/12. So does this need doing again or once it is done should it stay like that. Ihave just got home and seen the connectioon dropped about 20 mins ago. It looks like it has changed back to adsl2+.
ADSL line status
Connection information
Line state	Connected
Connection time	0 days, 0:18:51
Downstream	5,562 Kbps
Upstream	1,064 Kbps
ADSL settings
VPI/VCI	0/38
Type	PPPoA
Modulation	ITU-T G.992.5
Latency type	Interleaved
Noise margin (Down/Up)	3.3 dB / 5.2 dB
Line attenuation (Down/Up)	48.0 dB / 23.0 dB
Output power (Down/Up)	0.0 dBm / 12.9 dBm
Loss of Framing (Local)	21
Loss of Signal (Local)	3
Loss of Power (Local)	0
FEC Errors (Down/Up)	993953 / 4294967263
CRC Errors (Down/Up)	6 / N/A
HEC Errors (Down/Up)	N/A / 0
Error Seconds (Local)	33455
		Hide Details
Software version 8.1.H.U (Type A) | Access Click to activate accessibility mode | Time and date  15:16:43  13/04/2012
 I have seen that the bt speedtester isnt working properly so this is the speedtester.net results.
http://www.speedtest.net/result/1892206569.png
Cheers.
Message 113 of 121
connection still on 3.3db noise margin and adsl2+ so that's good.  a lot of error seconds for a short time connected but speedtest is consistent with your connection speed
lobsterboy1
Message 114 of 121
Hi, It has been like this for quite a while now I have fitted a filtered face plate about 2 weeks ago and left it to sort its self out but still get connection dropping daily. I have had my noise margin reset to 6db and still get drop outs. What do the error seconds mean. Is that something at my end I can try and sort or not. Thanks for any help
Message 115 of 121
error seconds this link explains about error messages http://www.kitz.co.uk/adsl/linestats_errors.htm
lobsterboy1
Message 116 of 121
It might be me but if there are 33455 seconds with errors in that would mean over 9 hours worth but the connection time is 18.51 there are only 1131 seconds altogether. Or have I totally misunderstood it.
Message 117 of 121
the error seconds are showing noise on the line and the 3db noise margin is not helping it need reseting to 6db
lobsterboy1
Message 118 of 121
The mods reset my noise margin to 6db on 19/03/12 does that need doing again and if so why doesn't it stay done. At the minute it is showing the longest connection I have seen in a while.
ADSL line status
Connection time 1 day, 3:42:13
Downstream 5,646 Kbps
Upstream 1,064 Kbps
ADSL settings
VPI/VCI 0/38
Type PPPoA
Noise margin (Down/Up) 2.5 dB / 5.4 dB
Loss of Framing (Local) 32
Loss of Signal (Local) 4
FEC Errors (Down/Up) 112791573 / 4294967234
CRC Errors (Down/Up) 24488 / N/A
Error Seconds (Local) 1
Message 119 of 121
a lower noise margin has been trialled since the end of last year on stable lines you could ask the mods if they can lock your noise margin at 6db as the lower margin is no good on your line
lobsterboy1
Message 120 of 121
Hi, Seems my connection has sorted its self out I am now at over 4 days connected and I have never seen that before so something somewhere has sorted it self out fingers crossed it stays like this. Thanks for all your answers especially John, Keith and Jolly.
ADSL line status
Connection time	4 days, 14:43:04
Downstream	5,280 Kbps
Upstream	1,060 Kbps
ADSL settings
VPI/VCI	0/38
Type	PPPoA
Noise margin (Down/Up)	4.3 dB / 5.9 dB
FEC Errors (Down/Up)	178280883 / 4294967264
CRC Errors (Down/Up)	9267 / N/A
Error Seconds (Local)	54500
 Cheers.
