lobsterboy1
Message 101 of 121
Re: Connection dropping out
Hi, this morning at about 5:15 I saw the home hub do something I haven't seen before the b light started flashing orange for about 20 seconds then the wireless and power light went off. The hub then had no lights on at all for around 30 seconds then began to power up again just like the reset button had been pressed but it had not. I have never seen the hub do this before is this normal. I had to leave for work so was unable to get stats to post. I will do when I get home. Cheers
Message 102 of 121
it is possible it was a firmware update to the hub
lobsterboy1
Message 103 of 121
Hi just got home and these are the stats. Seems the hub shows a longer connection time than I would have thought.
ADSL line status
Connection information
Line state Connected
Connection time 0 days, 11:55:15
Downstream 5,778 Kbps
Upstream 1,071 Kbps
ADSL settings
VPI/VCI 0/38
Type PPPoA
Modulation ITU-T G.992.5
Latency type Interleaved
Noise margin (Down/Up) 2.6 dB / 5.4 dB
Line attenuation (Down/Up) 48.0 dB / 23.0 dB
Output power (Down/Up) 0.0 dBm / 12.9 dBm
Loss of Framing (Local) 0
Loss of Signal (Local) 0
Loss of Power (Local) 0
FEC Errors (Down/Up) 62368982 / 4294967264
CRC Errors (Down/Up) 11250 / N/A
HEC Errors (Down/Up) N/A / 0
Error Seconds (Local) 1
Cheers
Message 104 of 121
could you please check and see if your hub firmware has updated
lobsterboy1
Message 105 of 121
How can I tell?
Message 106 of 121
which hub are you using
lobsterboy1
Message 107 of 121
It's a home hub 2 type A
Message 108 of 121
this tells you  http://bt.custhelp.com/app/answers/detail/a_id/11585
lobsterboy1
Message 109 of 121
It has been on that software a long time I have seen it at the bottom of every page also when I check the stats there can be no error seconds one second then if I refresh the browser it can jump up by thousands is this right.
ADSL line status
Connection time 0 days, 13:02:54
Upstream 1,071 Kbps
ADSL settings
VPI/VCI 0/38
Type PPPoA
Noise margin (Down/Up) 2.3 dB / 5.2 dB
FEC Errors (Down/Up) 73809803 / 4294967264
CRC Errors (Down/Up) 16368 / N/A
Error Seconds (Local) 8385
Software version 8.1.H.U (Type A) | Access | Time and
lobsterboy1
Message 110 of 121
Hi, the connection is still dropping at least once a day and now the modulation has changed.
ADSL line status
Connection time 0 days, 1:19:11
Downstream 5,687 Kbps
Upstream 1,064 Kbps
ADSL settings
VPI/VCI 0/38
Type PPPoA
Modulation ITU-T G.992.3
Noise margin (Down/Up) 3.1 dB / 6.3 dB
Line attenuation (Down/Up) 44.5 dB / 23.0 dB
Loss of Framing (Local) 21
Loss of Signal (Local) 3
FEC Errors (Down/Up) 3934311 / 4294967264
CRC Errors (Down/Up) 1042 / N/A
Error Seconds (Local) 32188
There must be a problem somewhere. Anyone got any more ideas.
