dazzarfc12
Message 1 of 4
Connection dropping
Connection has been dropping out alot can anyone help had this year ago with normal broadband bt is terrible
3 REPLIES 3
DavidM
Moderator
Moderator
Message 2 of 4
Re: Connection dropping
Hi @dazzarfc12 and thanks for posting.
Sorry you're connection is dropping. Can you give us more detail on what the problem is? Are you having wireless problems? Do the hub lights change? Is there any noise on the line? If you can us as much detail as possible we'll try to help.
Cheers
David
dazzarfc12
Message 3 of 4
It's just sometimes the pages don't load it's very annoying liie the wireless bars only flash 1 arrow like there is 2 little arrows on the connection thing.
pippincp
Message 4 of 4
You're not really being of help here to diagnose your problem. Don't worry we'll try and guide you through at a pace suitable to you.
Is there any way you can check the connection with a wired device?
Do any of the lights on the hub change?
Do you have a corded phone? If so can you do quiet line test, 17070 option 2 the line should be silent between announcements.
