Message 1 of 20
Connection has taken a dive
HH2 has dived, snr got reset was very stable at 6db then it dropped to 3db and was still stable then back to 6db for over a week stable and now its upto 12 db and my download speed is heading south.
Now this auto garb at the exchange end is getting out of hand, ive already lost 3mbps from the profile and down to 6mbps actual speed and i think it'll get worse, someone has to intervene, (if it aint broken dont fix it) so stable at 3 and 6db so why all of a sudden it should decide to rocket is beyond me.
ADSL line status
Connection information
Line stateConnected
Connection time0 days, 1:13:18
Downstream7,079 Kbps
Upstream888 Kbps
ADSL settings
VPI/VCI0/38
TypePPPoA
ModulationITU-T G.992.5
Latency typeInterleaved
Noise margin (Down/Up)12.0 dB / 13.7 dB
Line attenuation (Down/Up)41.0 dB / 23.5 dB
Output power (Down/Up)0.0 dBm / 12.8 dBm
Loss of Framing (Local)0
Loss of Signal (Local)0
Loss of Power (Local)0
FEC Errors (Down/Up)416 / 4294967264
CRC Errors (Down/Up)0 / 2147480000
HEC Errors (Down/Up)nil / 0
Error Seconds (Local)0
FAQ
Results Image not loaded
Test1 comprises of two tests
1. Best Effort Test: -provides background information.
Download Speed
6414 Kbps
0 Kbps7150 Kbps
Max Achievable Speed
 Download speedachieved during the test was - 6414 Kbps
 For your connection, the acceptable range of speedsis 2000-7150 Kbps.
 Additional Information:
 Your DSL Connection Rate :7079 Kbps(DOWN-STREAM), 888 Kbps(UP-STREAM)
 IP Profile for your line is - 6000 Kbps
The throughput of Best Efforts (BE) classes achieved during the test is - 18.69:20.04:61.28 (SBE:NBE:PBE)
These figures represent the ratio while sententiously passing Sub BE, Normal BE and Priority BE marked traffic.
The results of this test will vary depending on the way your ISP has decided to use these traffic classes.
2. Upstream Test: -provides background information.
Upload Speed
721 Kbps
0 Kbps888 Kbps
>Upload speed achieved during the test was - 721 Kbps
 Upstream Rate IP profile on your line is - 888 Kbps
19 REPLIES 19
Message 2 of 20
Re: Connection has taken a dive
this looks like the result of the disconnections due to the bad filter which you had yesterday.  Like you tell eveyone else it will sort itself if you stay connected 24/7 but it may take longer than your normal 3/5 days - patienceSmiley Wink
Message 3 of 20
Like i tell others Form submitted lol
Message 4 of 20
should wait to show stable connection before sending the form just in case you have not solved the disconnection problem.
Still if solved by the time mods reply you probably find that it has sorted itself
Message 5 of 20
Its still getting worse and is now back to what it was when adsl2+ went live on the line over 14db SNR Down, Personally i'd take the auto feature of the exchange and shoot it, because like i said if a connection is rock solid at 3db & 6db for downloading and gaming for hours on end without causing lag or sync issues then personally i think we should be able to say im stable at 6db and just leave it there through that auto-garb out.
My Opinion is my own on my own line as im the end user and its upto me to see the line stability if its not stable i'd be on here like i am now typing up that there is a problem.
Thanks for the rant!
IceZaroth
BT Community Helper
ADSL line status
Line stateConnected
Connection time0 days, 5:50:46
Downstream6,338 Kbps
Upstream888 Kbps
ADSL settings
VPI/VCI0/38
TypePPPoA
Noise margin (Down/Up)14.2 dB / 6.1 dB
Line attenuation (Down/Up)41.0 dB / 23.4 dB
Output power (Down/Up)0.0 dBm / 4.1 dBm
Loss of Framing (Local)11
Loss of Signal (Local)1
FEC Errors (Down/Up)6708 / 0
CRC Errors (Down/Up)18 / 2147480000
Error Seconds (Local)23
Message 6 of 20
looks like you have a noise problem - are the filters ok or was it just the one that caused the problem?
Message 7 of 20
just that one, the current one is not affected when making voice calls.
Message 8 of 20
HH2 just resync'ed and now 15.3db of noise ... PLEASE BT SORT THIS HIGH SNR
ADSL line status
Line stateConnected
Connection time0 days, 0:00:46
Downstream6,335 Kbps
Upstream1,191 Kbps
ADSL settings
VPI/VCI0/38
TypePPPoA
Noise margin (Down/Up)15.3 dB / 5.9 dB
Output power (Down/Up)0.0 dBm / 12.6 dBm
FEC Errors (Down/Up)1 / 0
HEC Errors (Down/Up)nil / 15
Message 9 of 20
did it hold connection all day yesterday?
Message 10 of 20
yes last time i seen it said 1 day and so many hours, but i still dont get why my connection is more stable at 6db down and now at 15db down its just sloooowwwww
ADSL settings
VPI/VCI0/38
TypePPPoA
Noise margin (Down/Up)14.8 dB / 1.8 dB
Line attenuation (Down/Up)41.5 dB / 23.7 dB
Output power (Down/Up)0.0 dBm / 13.0 dBm
FEC Errors (Down/Up)83 / 0
