licquorice
Message 11 of 19
Re: Connection issues - possible wiring problem
It looks to me as though it using one wire from each pair and the orange wire has been terminated on terminal 3 instead of terminal 2. Its an extremely simple matter to move it, you can always put it back if it doesn't work.
It works when connected to terminal 3 as the broadband signal will be going via a capacitor, phone wouldn't work as it would block the DC but broadband will pass through but would be improved by using correct connections.
azzybish
Message 12 of 19
Black is connected to 5 and orange to 3. I've ordered an IDC so i can do it properly, should arrive tomorrow. I've read online that i could determine which are the correct cables using a multimeter - can anyone advise how i could do that?
licquorice
Message 13 of 19
Ideally the 2 live wires should be either orange/white or black/green as they are twisted pairs, but obviously you will have to use whatever is connected at the pole end. Whatever wires have been used, they should be connected to terminals 2 & 5. First try connecting green to 2, if that doesn't work move orange to 2.
azzybish
Message 14 of 19
I disconnected the orange from 3 and connected the green to 2 - it has now synced at the below specs! This is after 10 mins uptime - is the FEC errors anything to worry about/can i do anything else to reduce them?
SNR Margin (dB)3.36.6
Attenuation (dB)32
Output Power (dBm)11.53.5
Attainable Rate (Kbps)23164 kbps1088 kbps
Rate (kbps)20078 kbps1088 kbps
K (number of bytes in DMT frame)15351
R (number of check bytes in RS code word)166
S (RS code word size in DMT frame)05
D (interleave depth)964
Delay (msec)55
FEC73790
CRC00
Total ES00
Total SES00
Total UAS00
Total LOSS00
imjolly
Message 15 of 19
the FEC errors are inleaving doing it's job of forward error correction to help your conenction - nothing to be concerned
azzybish
Message 16 of 19
great thanks for your help. it does make me wonder why it was working with the ring wire connected in 3 but wouldnt with just the black in 5.
if it is now working does that mean that green is definitely the correct one to have in 2?
imjolly
Message 17 of 19
did you disconnect terminal 3?
connection looks good now and hopefully will remain stable
azzybish
Message 18 of 19
Yes i disconnected the orange from 3 and put the green into 2, so now its just black in 5 and green in 2.
imjolly
Message 19 of 19
that should be ok now
