robjohnmoore
Message 1 of 7
Connection keeps dropping
Our slow broadband has recently been dropping and reconnecting all day long. Below is an example of this evening  any ideas what the issue is?
22:13:48, 12 Dec.( 102.220000) WAN operating mode is ADSL
22:13:48, 12 Dec.( 102.220000) Last WAN operating mode was ADSL
22:13:47, 12 Dec.( 100.930000) PPP IPCP Receive Configuration ACK
22:13:46, 12 Dec.( 100.650000) PPP IPCP Send Configuration Request
22:13:46, 12 Dec.( 100.640000) PPP IPCP Receive Configuration NAK
22:13:46, 12 Dec.( 100.520000) PPP IPCP Send Configuration ACK
22:13:46, 12 Dec.( 100.520000) PPP IPCP Receive Configuration Request
22:13:46, 12 Dec.( 100.290000) PPP IPCP Send Configuration Request
22:13:44, 12 Dec.( 98.710000) PPPoA is up -​ VPI: 0, VCI: 38 Down Rate=1888Kbps, Up Rate=448Kbps; SNR Margin Down=12.6dB, Up=20.0dB
22:13:44, 12 Dec.( 98.690000) CHAP authentication successful
22:13:44, 12 Dec.( 98.530000) CHAP Receive Challenge
22:13:44, 12 Dec.( 98.370000) Starting CHAP authentication with peer
22:13:44, 12 Dec.( 98.370000) PPP LCP Send Configuration ACK
22:13:44, 12 Dec.( 98.370000) PPP LCP Receive Configuration Request
22:13:41, 12 Dec.( 95.310000) PPP LCP Receive Configuration ACK
22:13:41, 12 Dec.( 95.260000) PPP LCP Send Configuration Request
22:13:41, 12 Dec.( 95.260000) PPP LCP Receive Configuration Reject
22:13:41, 12 Dec.( 95.020000) PPP LCP Send Configuration Request
22:13:27, 12 Dec.( 81.790000) ETHoA is up -​ VPI: 0, VCI: 35 Down Rate=1888Kbps, Up Rate=448Kbps; SNR Margin Down=12.6dB, Up=20.0dB
22:13:27, 12 Dec.( 81.790000) ATM over DSL is up
22:12:45, 12 Dec.( 39.290000) WAN Auto-​sensing running.
21:55:41, 12 Dec.( 100.480000) WAN operating mode is ADSL
21:55:41, 12 Dec.( 100.480000) Last WAN operating mode was ADSL
21:55:40, 12 Dec.( 99.250000) PPP IPCP Receive Configuration ACK
21:55:40, 12 Dec.( 99.200000) PPP IPCP Send Configuration Request
21:55:40, 12 Dec.( 99.190000) PPP IPCP Receive Configuration NAK
21:55:40, 12 Dec.( 99.190000) PPP IPCP Send Configuration ACK
21:55:40, 12 Dec.( 99.180000) PPP IPCP Receive Configuration Request
21:55:40, 12 Dec.( 98.940000) PPP IPCP Send Configuration Request
21:55:38, 12 Dec.( 97.360000) PPPoA is up -​ VPI: 0, VCI: 38 Down Rate=1856Kbps, Up Rate=448Kbps; SNR Margin Down=13.4dB, Up=20.0dB
6 REPLIES 6
Keith_Beddoe
Message 2 of 7
Re: Connection keeps dropping
Welcome to this user forum.
Is there any noise on your phone calls? Dial 17070 and select option 2, there should be no noise between the announcements.
imjolly
Message 3 of 7
have you tried using the test socket with a new filter to see if this helps stability by eliminating your extension wiring and master front plate as causing problems
can you enter phone number and post results  delete number  https://www.btwholesale.com/includes/adsl/main.html
can you post stats from your hub
robjohnmoore
Message 4 of 7
I dom't use micro filters as have a master socket that has one socker for phone and one for DSL. So not sur that is the issue.
below is the output from the adsl checker
Exchange HASLINGTON is served by Cabinet 87
Featured ProductsDownstream Line Rate(Mbps)Upstream Line Rate(Mbps)Downstream Range(Mbps)WBC FTTP Availability Date   ADSL ProductsDownstream Line Rate(Mbps)Upstream Line Rate(Mbps)Downstream Range(Mbps)Availability Date Left in JumperOther Offerings     Availability Date   Premise environmentStatus
FTTP on Demand33030--Available----
WBC ADSL 2+Up to 13--7.5 to 17.5Available----
WBC ADSL 2+ Annex MUp to 13Up to 17.5 to 17.5Available----
ADSL MaxUp to 7--6 to 8Available----
WBC Fixed Rate2----Available----
ADSL Multicast------Available----
Bridge TapU
VRIN
NTEFaceplateN
Last Test Date08-06-2018
FTTP is not available.
For all ADSL and WBC Fibre to the Cabinet (VDSL or G.fast) services, the stable line rate will be determined during the first 10 days of service usage.
This line is on a Market B Exchange.
In order to be eligible for handback, downstream speed should be less than Downstream Handback Threshold values.
Throughput/download speeds will be less than line rates and can be affected by a number of factors within and external to BT's network, Communication Providers' networks and within customer premises.
The Stop Sale date for Datastream is from 30-Jun-2012; the Formal Retirement date for Datastream is from 30-Jun-2014. The Stop Sale date for IPstream is from 31-Dec-2012; the Formal Retirement date for IPstream is from 30-Jun-2014.
If the End User wishes to migrate from their current Broadband supplier they will need to contact the Broadband supplier they want to take service from to arrange for the service to be migrated.
Please note that postcode and address check results are indicative only. Most accurate results can be obtained from a telephone number, NAD, UPRN or Access Line ID (ALID) check.
Note:
Thank you for your interest.
Keith_Beddoe
Message 5 of 7
Which socket do you have?
Master socket with two sockets
Which BT Home hub are you using, it should be a home hub 3 or home hub 4 for ADSL?
imjolly
Message 6 of 7
even if you have a filtered master socket you need to try the test socket with a filter to eliminate your internal wiring and faceplate from cause the instability problems
I also see you are on adslmax up to 8mb whereas your exchange is adsl2 unabled and you could upgrade and get an expected speed od about 13mb maybe better with up speed increasing by about 100%.. the forum mods could help if you decide to upgrade
robjohnmoore
Message 7 of 7
Broadband is now more stable. Managed 24 hours before a restart. Today I was finally able to order Fibre with an estimate of 79-80Mbps. Only downside is that I have to wait unti 4th Jan. Is there anything that can be done between now and then to get more then the 1.6Mbps I have currently.
