Pyke405
Message 1 of 6
Connection keeps dropping
we have a big issue with out Internet connection- it keeps dropping out and and devices ices can see the hub they cannot connect Unless we restart the hub.  The problem is that happens in excess of 20 times a day, for some reason concentrated around particular points in time (I am writing this after it has dropped out 6 times in a row this evening.)
we have a home hub 2
below are the ADSL stats from the hub.
can someone please help!
thanks,
mark
ADSL line status
Connection information
Line stateConnected
Connection time0 days, 0:09:00
Downstream15,323 Kbps
Upstream1,040 Kbps
ADSL settings
VPI/VCI0/38
TypePPPoA
ModulationITU-T G.992.5
Latency typeInterleaved
Noise margin (Down/Up)14.9 dB / 5.1 dB
Line attenuation (Down/Up)8.0 dB / 4.0 dB
Output power (Down/Up)21.1 dBm / 12.4 dBm
5 REPLIES 5
john46
Message 2 of 6
Re: Connection keeps dropping
Pyke405
Message 3 of 6
Should I see the warm kernel restart in the event log below?
This is what I have in the event log if I am doing it correctly
Time & Date Message
22:54:14  10 DecSNTP Synchronised to server: 213.123.26.170
22:54:14  10 DecSNTP Systemtime update: time setting 00:04:06 > new time setting: 22:54:14
00:02:29   1 JanUPnP action 'AddPortMapping' from ip=192.168.1.70 (Success)
00:02:25   1 JanUPnP action 'AddPortMapping' from ip=192.168.1.70 (Success)
00:02:23   1 JanUPnP action 'DeletePortMapping' from ip=192.168.1.70 (No such entry in array)
00:02:21   1 JanUPnP action 'DeletePortMapping' from ip=192.168.1.70 (No such entry in array)
00:02:20   1 JanLOGIN User admin logged in on [HTTP] (from 192.168.1.70)
00:02:19   1 JanCONFIGURATION saved by TR69
00:02:11   1 JanLOGIN User Basic logged in on [HTTP] (from 192.168.1.70)
00:01:47   1 JanVOIP: [2.0A] [442030526676] [FXS DECT1 DECT2 DECT3 DECT4 DECT5] 200 OK - SIP message received
00:01:46   1 JanVOIP: [2.0A] [442030526676] [FXS DECT1 DECT2 DECT3 DECT4 DECT5] REGISTER - SIP message sent
00:01:44   1 JanPPP link up (Internet) [31.52.103.189]
john46
Message 4 of 6
I would think the hub is on its way out
begegg
Message 5 of 6
no my hub does the same and is only 6 months old
john46
Message 6 of 6
the poster has a home hub 2 and it a known problem with those hubs and has shown to fail soon after as the device is now getting quite old now
I suggest you look at the link i posted
