Frustratednoob
Message 1 of 9
Connection lost whenever Ethernet cable plugged in from youview
Hi, I am new to BT infinity and have been trying to set it up but am encountering a major fault.
Essentially I can connect the hub and get broadband internet, however this completely disconnects when I connect the Ethernet cable from the youview box to the hub and it won't reconnect to the Internet no matter how many times I restart it and it will just flash orange forever unless I unplug the Ethernet cable and restart the hub.
This means I cannot get any of the Internet services and channels on my youview box and have to leave it unplugged. There is no way to connect wirelessly that I am aware of with it.
The only occasions where I have been able to get my vt service up and running is by unplugging the Ethernet cable, resetting the hub, letting it connect to the Internet and then plugging in the Ethernet. After doing this several times, it may eventually work and remain connected. This will only work for a few hours and then it will disconnect and I have to start the whole process again.
Technical support are sending a new hub but I doubt this is going to fix the problem. I wonder whether it might be a more technical issue to do with connection settings, but I am not very tech savvy and would be very grateful for any advice and thoughts. Thanks and sorry to be so longwinded!!
8 REPLIES 8
pippincp
Message 2 of 9
Re: Connection lost whenever Ethernet cable plugged in from youview
This seems to be more of a problem with the youview box or ethernet cable you are using.
Martin--W
Retired BT Expert
Message 3 of 9
Hello @Frustratednoob
Sorry to hear you're experiencing issues connecting to the internet. If you'd like to private message me your phone number or account number would be happy to see if I can help.
Hopefully the new hub will resolve any issue, but am happy to discuss any problems you have.
Martin.
stephenwhite990
Message 4 of 9
you are plugging it into a yellow ethernet port on the hub and NOT the red port on the hub
StewM
Distinguished Guru
Message 5 of 9
Hi, you have set up the Youview Box correctly? Try these help pages.
Stew
Frustratednoob
Message 6 of 9
Thanks everyone for the responses. The new hub has arrived and seems to be working so far, though only just set up. Will let you know how it goes!
Frustratednoob
Message 7 of 9
Unfortunately the victory was short lived. Woke up this morning with it disconnected and unable to reconnect again with the Ethernet cable plugged in. So not a problem with the hub then...
NeilO
Moderator
Moderator
Message 8 of 9
@Frustratednoob if you PM your details over to @Martin--W our BT TV expert he'll be able to help you get this sorted.
Frustratednoob
Message 9 of 9
Thank you, will do!
