TUX
Message 11 of 37
Re: Connection problems for 6 months !
Hi @PaddyB
My connection has deteriorated and is now dropping constantly regardless of the high SNR.
There is obviously something physically wrong with this line, see anything from your end ?
Ryan
RobbieMac
Moderator
Moderator
Message 12 of 37
Hi @TUX
Sorry to see you're still having problems.
Can you post your current Hub stats please?
Thanks,
Robbie
TUX
Message 13 of 37
Information for Helpdesk agents
When contacting the BT Broadband helpdesk, the agent might ask you for details about your BT Home Hub. This page contains all of the information they are likely to request.
1. Product name: BT Home Hub
2. Serial number: +068543+NQ44325803
3. Firmware version: Software version 4.7.5.1.83.8.236.1.2 (Type A) Last updated Unknown
4. Board version: BT Hub 5A
5. DSL uptime: 0 days, 00:13:25
6. Data rate: 448 / 2368
7. Maximum data rate: 1016 / 2496
8. Noise margin: 18.0 / 9.9
9. Line attenuation: 31.5 / 57.2
10. Signal attenuation: 31.5 / 55.5
11. Data sent/received: -
12. Broadband username: bthomehub@btbroadband.com
13. BT Wi-fi: Yes
14. 2.4 GHz Wireless network/SSID: BTHub5-N5T7
15. 2.4 GHz Wireless connections: Enabled (802.11 b/g/n (up to 144 Mb/s))
16. 2.4 GHz Wireless security: WPA2
17. 2.4 GHz Wireless channel: Automatic (Smart Wireless)
18. 5 GHz Wireless network/SSID: BTHub5-N5T7
19. 5 GHz Wireless connections: Enabled (802.11 a/n/ac (up to 1300 Mb/s))
20. 5 GHz Wireless security: WPA2
21. 5 GHz Wireless channel: Automatic (Smart Wireless)
22. Firewall: Default
23. MAC Address: d0:84:b0:e5:98:08
24. VPI/VCI: 0 / 38
25. Modulation: G.992.1 Annex A
26. Latency type: Interleaved
27. Software variant: AA
28. Boot loader: 1.0.0
TUX
Message 14 of 37
Phoned and reported fault, tests done and apparently there is a fault external to the property.
Waiting on a text to confirm engineer visit and instead I get
"Hello, BT here. Your service should be back up and running now. If you're still having any problems please reply to this message or call us on 0800800151 from a mobile its 03301234151. Thanks."
Guess I'm chasing my tail again !
Help appreciated, thanks.
PaddyB
Moderator
Moderator
Message 15 of 37
Hi @TUX,
Thank you for posting back. I'm sorry to see that things have got worse with your connection. I'll be able to take a look at this for you and run a few checks on your line. Please can you send me in your details using the "Contact The Mods" link found in my profile?
PaddyB
TUX
Message 16 of 37
Hi @PaddyB
I cant seem to find the link in your profile to "contact the mods" Smiley Frustrated
Im logged in but only see the PM option, i've used it before but its not showing as far as I can tell !
PaddyB
Moderator
Moderator
Message 17 of 37
Hi @TUX,
OopsSmiley Embarassed
You should be able to see that now.
PaddyB
TUX
Message 18 of 37
@PaddyB
Done, thought i was going mental there !Smiley Very Happy
TUX
Message 19 of 37
Spoiler
Hi @PaddyB
Engineer been and gone, can't find any faults and says the line is syncing at nearly 3meg and the upload 448kbs.
May well be reporting that but as I said and he confirmed via his laptop connected directly to ethernet it's nowhere near that speed !
My upload speed is consistently under 100kbs, it's unusable in this state.
Frustration is compounded by the fact the help desk he phoned said my connection has been stable for 2 weeks !
That's total BS !
They also said my exchange was due to be upgraded to 21CN on the 1st march and I'm as well waiting until then to see if it helps any.
Can you confirm if this is the case and what difference it will make ?
Cheers
imjolly
Message 20 of 37
try entering your phone number and post results  remember delete number but leave exchange and cab  http://dslchecker.bt.com/adsl/adslchecker.welcome
due to your distance from the exchange upgrade to adsl2 will make little difference to your down speed if any but I would hope for about 100% increase in up speed
