Samantha1978
Message 1 of 9
Connection problems
I am very angry at the level of service from bt, ever since I started with bt I have had continually having connection problems everyday, at least 10 times rebooting and disconnecting. We are on our second hub and was promised a third two weeks ago which we have never received. Awful connection issues. I called four times to be cut off by the adviser every time. I'm paying for a service that's not good, in fact rubbish, I'm taking this to watchdog. I'm looking for another provider
8 REPLIES 8
Keith_Beddoe
Message 2 of 9
Re: Connection problems
Welcome to this user forum. @Samantha1978
Is there any noise on your phone calls? Dial 17070 and select option 2, there should be no noise between the announcements.
Noise is usually the cause of disconnections.
Do the lights on your BT Home hub change colou when you get the disconnections?
If its a line problem, it will still be there with another provider. This forum is the best way to get the problem sorted.
Samantha1978
Message 3 of 9
No noise, constant blue to orange, we were with sky for 6 years with no problems, just bt.
Samantha1978
Message 4 of 9
We also have to reboot the tv box as the apps don't work or freeze. It's very frustrating
Keith_Beddoe
Message 5 of 9
I have asked a moderator to provide assistance, they will post an invite on this thread.
They are the only BT employees on this forum, and are based in the UK.
Meanwhile it would help if you could answer a few question.
Which one of these matches your master phone socket?
Do you have any extension sockets?
I assume you have the new smart hub?
Please could you post the information from the smart hub, using this link.
http://192.168.1.254/0000012803/gui/#/technicalLog/information
One of the moderators will be able to look at your connection from the BT end as well.
OlgaC
Moderator-Retired
Message 6 of 9
Hi @Samantha1978
I would like to take a look and see what is causing your connection problems. Can you send over your details by clicking on the contact link within my profile and one of the team will be in touch.
Thanks,
OlgaC
Samantha1978
Message 7 of 9
Socket is first picture, and it's a new smart hub my second one
Samantha1978
Message 8 of 9
No extension sockets
Keith_Beddoe
Message 9 of 9
@Samantha1978
Please could you try connecting things up as shown below, and see if you still get the connection problems.
Leave it connected this way for a few days.
Thanks.
Could you also make sure you fill in the request form on the link @OlgaC provided for you.
