Message 11 of 14
Re: Connection speed (download/upload speeds) question
you have got the drop in noise margin but you have been set on fast instead of interleaved resulting in a very large number of crc/hec errors.  this will be killing your download speed which you should see if you run btpeedtester beta version.  need mods to put on interleaved
Phil_Redbud
Message 12 of 14
Thankyou IMJ, I doubt I can get the page up but I appreciate your help very much, Phil.
Phil_Redbud
Message 13 of 14
After 47 attempts (seriously 47) I had one test show results as........
FAQ
Results Image not loaded
1. Best Effort Test: -provides background information.
Download Speed
0.76 Mbps
0 Mbps
7.15 Mbps
Max Achievable Speed
Download speedachieved during the test was - 0.76 Mbps
For your connection, the acceptable range of speeds is 2 Mbps-7.15 Mbps.
IP Profile for your line is - 7.61 Mbps
2. Upstream Test: -provides background information.
Upload Speed
0.69 Mbps
0 Mbps
0.83 Mbps
Upload speed achieved during the test was - 0.69Mbps
Additional Information:
Upstream Rate IP profile on your line is - 0.83 Mbps
This test was not conclusive and further testing is required.This might be useful for your Broadband Service Provider to investigate the fault.
If you wish to carry out further tests,please click on 'Continue' button.If not, please close the window using 'Exit' button and contact your ISP for further assistance with these results.
I have contactacted the mods again as IMJ suggests, now the obligatory 5 day wait for a reply.
I went with BT for the simple reason I didn't want to take time off work to let Virgin in. We live and learn eh!.
Message 14 of 14
the mods will contact you normally within 3 working days it can sometimes be longer if they get a backlog
