Message 1 of 1
Connection speed vs download speed
I have recently had an upgrade from 160Mb/s FTTC to 330Mb/s FTTC with a guaranteed minimum speed of 150Mb/s. My home hub shows:
Data rate:  49.131 Mbps / 328.823 Mbps
Maximum data rate:  76.975 Mbps / 343.771 Mbps
However on various speed tests including BT my download speed is 140Mb/s and upload speed 48Mb/s with a ping of 7ms. The download speed is the same as before the upgrade and the upload speed has significantly increased.
Should there be such a difference between the connected data rate and tested download speed and does the guaranteed speed refer to the connection speed or download speed?
