Faouzi64
Message 1 of 15
Connection to Internet failed
hello to anyone who can help!
Youview has been working OK for 2months but 6days ago - BT sport channels were not available anymore
Status says connected
when searching for new connection - more precisely it says connected to router but not the Internet.
Tried
Ethernet cable direct from router to youview
factory reset
software reset.
rebooted modem and router many times.
gone through numerous diagnostics via the live chat.
got instructions to reset in maintenance menu...I replied saying still not working. over a week now and no reply. they've given up on me!
all other devices work...PCs, phones!
wireless, powerline adapters and wired devices all work fine - connecting to the router and accessing the Internet.
Problem
last solution offered by the help desk the visit of an engineer...
so now facing the delightfull "if its your fault it will cost you £120 from BT"
why I am worried and not happy?
Also - I'm using a WIFI bridge not bought via BT, worried BT engineer will blame that on the fault and charge me for the visit.
I'm so unsure about the nature of the problem?? connected to router but not the Internet?? I cant help thinking is there something in the settings that changed on their Own or an update of the software...
as sure as I can be that the router is fine - but I think the box is faulty but I cant risk having to pay £120 - will have to continue with no BT sport channels and on demand services so I might as well cancel subscription.
if any one can help i would be very grateful
14 REPLIES 14
licquorice
Message 2 of 15
Re: Connection to Internet failed
Have you inadvertently turned off IGMP snooping on your router.
Faouzi64
Message 3 of 15
I don't know what it is, but I don't think so... I don't have any connection issues with my devices
licquorice
Message 4 of 15
IGMP snooping is only required for tv
Faouzi64
Message 5 of 15
Can I check that?
licquorice
Message 6 of 15
It will be one of the settings on your router, check the manual to find the menu option
Faouzi64
Message 7 of 15
Ok I will try via my hub manager
Faouzi64
Message 8 of 15
I didn't change anything, everything seems OK! However I don't really know where to look...
licquorice
Message 9 of 15
What make and model of router is it?
Faouzi64
Message 10 of 15
BT SMART HUB
SI 5.0
