Message 1 of 6
I'm getting so frustrated trying to watch T.V in the bedroom and it just keeps on freezing constantly telling me I have network issues. According to my app there's no faults and the speed is fine well I beg to differ, if T.v wasn't attached to the wall it could of been out the window
Tags (1)
5 REPLIES 5
Message 2 of 6
Re: Connections
I assume you are using wireless connection not Ethernet so what have you tried?
which hub version are you using?
Message 3 of 6
Re: Connections
Hi yes its via wireless also how would I know what my Hub is its old I know that much
Message 4 of 6
Re: Connections
I've reset everything turned off on moved hub
Message 5 of 6
Re: Connections
have you turned of smart setup
Turn Off smart setup
have you split the networks
Split the networks
Have you tried changing wireless mode from 1 to either 2 or 3
Message 6 of 6
Re: Connections
No will try them now thanks
