ChrisB
Expert
Message 1 of 2
Consolidate phone and broadband bill
How do you get BT to run the broadband and phone contracts so they finish concurrently (i.e. together and not with an overlap)?
1 REPLY 1
Distinguished Guru
Message 2 of 2
Re: Consolidate phone and broadband bill
The only way I can think of is by starting them at the same time!
Does it matter?  You don't get cut off at the end of the minimum contract, just switched to rolling monthly billing instead.  If you need to, you can then cancel whenever you want to.
