MrJolly
Message 1 of 5
Constant 'Wire Lan Port x down/up' messages in HH5 event log, YMV102 messages in YouView
I have a problem with connectivity between my YouViewBox and HH5.
Broadband is connected (and very fast), but YouView box is constantly disconnecting and reconnecting to the router. Sometimes it doesn't interrupt viewing, sometimes it breaks it all together, sometimes I get the annoying messages at the top of the screen (YVM102) and then it says it is connected again.
I did a software reset via the maintenance menu on YouView box which seems to have improved things slightly, but I'm still getting the following in the activity log on the HH5 router. The killer question is, is the router causing the disconnects for some reason, or are the disconnects originating from the YouView box.
All wireless devices connected to HH5 have good, fast connections with no issues.
21:21:52, 14 Mar.(190799.140000) Lease for IP 192.168.1.68 renewed by host HUMAX (MAC cc:4e:ec:22:2c:c7). Lease duration: 30240 min
21:21:52, 14 Mar.(190799.140000) Device connected: Hostname: HUMAX IP: 192.168.1.68 MAC: cc:4e:ec:22:2c:c7 Lease time: 30240 min. Link rate: 1000.0 Mbps
21:21:52, 14 Mar.(190799.060000) Lease requested
21:21:49, 14 Mar.(190796.350000) Wire Lan Port 4 up
21:21:46, 14 Mar.(190793.100000) Device disconnected: Hostname: HUMAX IP: 192.168.1.68 MAC: cc:4e:ec:22:2c:c7
21:21:46, 14 Mar.(190793.350000) Wire Lan Port 4 down
21:20:36, 14 Mar.BLOCKED 1 more packets (because of First packet is Invalid)
21:20:36, 14 Mar.OUT: BLOCK [65] First packet is Invalid (Invalid tcp flags for current tcp state: TCP [192.168.1.68]:40212-​>[213.1.75.11]:80 on ppp3)
21:19:17, 14 Mar.(190644.230000) Lease for IP 192.168.1.68 renewed by host HUMAX (MAC cc:4e:ec:22:2c:c7). Lease duration: 30240 min
21:19:17, 14 Mar.(190644.230000) Device connected: Hostname: HUMAX IP: 192.168.1.68 MAC: cc:4e:ec:22:2c:c7 Lease time: 30240 min. Link rate: 1000.0 Mbps
21:19:17, 14 Mar.(190644.160000) Lease requested
21:19:16, 14 Mar.(190643.230000) Wire Lan Port 4 up
21:19:13, 14 Mar.(190640.230000) Wire Lan Port 4 down
21:19:10, 14 Mar.(190637.890000) Device disconnected: Hostname: HUMAX IP: 192.168.1.68 MAC: cc:4e:ec:22:2c:c7
21:18:49, 14 Mar.(190616.160000) Wire Lan Port 4 up
21:18:48, 14 Mar.(190615.800000) Lease for IP 192.168.1.68 renewed by host HUMAX (MAC cc:4e:ec:22:2c:c7). Lease duration: 30240 min
21:18:48, 14 Mar.(190615.800000) Device connected: Hostname: HUMAX IP: 192.168.1.68 MAC: cc:4e:ec:22:2c:c7 Lease time: 30240 min. Link rate: 1000.0 Mbps
21:18:48, 14 Mar.(190615.720000) Lease requested
21:18:46, 14 Mar.(190613.160000) Wire Lan Port 4 down
21:18:45, 14 Mar.(190612.890000) Device disconnected: Hostname: HUMAX IP: 192.168.1.68 MAC: cc:4e:ec:22:2c:c7
21:18:07, 14 Mar.BLOCKED 1 more packets (because of First packet is Invalid)
21:18:06, 14 Mar.OUT: BLOCK [65] First packet is Invalid (Invalid tcp flags for current tcp state: TCP [192.168.1.68]:40212-​>[213.1.75.11]:80 on ppp3)
21:17:33, 14 Mar.OUT: BLOCK [65] First packet is Invalid (Invalid tcp flags for current tcp state: TCP [192.168.1.66]:57932-​>[46.19.168.101]:443 on ppp3)
21:16:54, 14 Mar.(190501.130000) Lease for IP 192.168.1.68 renewed by host HUMAX (MAC cc:4e:ec:22:2c:c7). Lease duration: 30240 min
21:16:54, 14 Mar.(190501.130000) Device connected: Hostname: HUMAX IP: 192.168.1.68 MAC: cc:4e:ec:22:2c:c7 Lease time: 30240 min. Link rate: 1000.0 Mbps
21:16:54, 14 Mar.(190501.060000) Lease requested
21:16:54, 14 Mar.(190501.830000) Wire Lan Port 4 up
21:16:51, 14 Mar.(190498.830000) Wire Lan Port 4 down
21:16:50, 14 Mar.(190497.830000) Device disconnected: Hostname: HUMAX IP: 192.168.1.68 MAC: cc:4e:ec:22:2c:c7
4 REPLIES 4
DavidM
Moderator
Moderator
Message 2 of 5
Re: Constant 'Wire Lan Port x down/up' messages in HH5 event log, YMV102 messages in YouView
Hi @MrJolly and thanks for posting.
I'm sorry you're having problems with the drops. You might have a faulty box so we'll need to run a few diagnostics to check that for you. Can you send over your details? You'll get the contact the moderators link in my profile.
Cheers
David
DavidM
Moderator
Moderator
Message 3 of 5
Hi @MrJolly,
As suspected it turned out the box was faulty but I'm glad we were able to get it replaced and everyting is sorted. If you have any further problems please post and we'll be happy to help.
Cheers
David
MrJolly
Message 4 of 5
Hi
Just to say thanks - YouView and HH5 seem to be playing together just fine now I have a replacement YouView box.
Cheers
Stephen154
Message 5 of 5
I seem to be getting this issue as well. The lan down up starts late at night until early morning.
