Message 11 of 16
Re: Constant disconnections
with all the disconnections you are experiencing you normally expect your noise margin to be high but yours is normal - about 6.  your stats look ok
have you or are you connected to the master socket or the test socket or somewhere else?
thebennyboy
Message 12 of 16
The hub and phone are in the main socket. (using a filter ofcourse)
Message 13 of 16
have you tried the test socket? only may help if you have extension sockets in your home
thebennyboy
Message 14 of 16
Turns out it was a faulty ADSL filter, just thought i would replace it just to try. Not a single drop out or drop of speed since. The so called "fault in the exchange" was a load of rubbish.
Message 15 of 16
that 'problem in the exchange' reason for your problem gets used a lot and is a good way to end the conversation
thebennyboy
Message 16 of 16
Gonna mark this as solved. Thanks for your help, imjolly.
