Tymo76
Message 1 of 4
Constant loging in to app
Is it normal that I have to login to the BT sport's app with my username and password every few hours? It wouldn't be too bad if it remembered my login details and I just had to hit "continue".
I know it's not like a major issue, but just wanted to know if this is normal.
3 REPLIES 3
NeilO
Moderator
Moderator
Message 2 of 4
Re: Constant loging in to app
@Tymo76 Thanks for posting and sorry about the delay replying, this was happening to a small number of customers but should have been sorted in the update released yesterday.
Tymo76
Message 3 of 4
Thanks Neil,as you say the update has sorted this out!
DavidM
Moderator
Moderator
Message 4 of 4
Thanks for letting us know @Tymo76. Appreciate you taking time to let us know it's sorted.
Cheers
David
