Message 31 of 58
Re: Constant voicemail icon
Hi Neil tried resetting the voicemail settings still the same glad to know your on to it
Damien
Message 32 of 58
@robboz wrote:
Hi Allan Quartermain.
Thanks for your reply.
My iPhone does not have an SD card
I have reset network settings to no avail
The battery, as far as I know is inaccessible to me.
I have reached the stage of requesting a replacement sim card which is scheduled to arrive tomorrow.
Fingers crossed.
Apologies: I think Android, and forget the battery in the i phone is fixed. Sorry.
AQ.
"Welcome to Royston Vasey - You'll never leave."
Distinguished Guru
Distinguished Guru
Message 33 of 58
The battery in my HTC One M8 is only replaceable with major surgery, AQ. So Androids are catching up, or dropping back depending on your point of view.
Message 34 of 58
Hello all
I have received and inserted the replacement nano sim from BT. about 4 hours ago. and activated.The voice mail red blob immediately disappeared. Exonerates Apple then?
I am still unable to set up voice mail other than to dial 1571. I did send a phone message to my-self, let is go through and left a message. The digit 1 in red appeared but the voice said 'there are no messages'. The red 1 faded away.
I'm happy the replacement sim solved the Red Blob problem but yet to find out whether any genuine voicemails are processed correctly.
Message 35 of 58
Hello NeilO
Happy to cofirrm that he replacement sim appears to have worked in that the constant red blob is no longer.
Moderator
Moderator
Message 36 of 58
Hi robboz,
That's great I'm glad it's sorted now. I've fed this back to the mobile team.
Cheers
Neil
Message 37 of 58
Yes I'm  pleased it's sorted too.
One thread worth noting here though, these smartphones only work if a two bob sim works properly. I recall a not disimilar issue with my provider when they sent a replacement  sim. That didnt solve it but the second replacement did.
AQ.
Message 38 of 58
I'm awaiting my replacement sim that Neil has kindly arraganged for me hope it solves my issue too
Message 39 of 58
Hi All new sim arrived today activated it and it's solved the problem no more annoying voicemail icon thanks to all and to Neil for arranging the replacement sim
Moderator
Moderator
Message 40 of 58
Hi Damien1,
That's great, I'm glad the replacement sim worked Smiley Happy
Neil
