bredbin
Newbie
Message 1 of 10
Constants Disconnects and Massive Speed Issues
Hi i have a huge problem here, have had bt total option 3 installed since september and have had 1Mb down although promised around 6Mb. After ringing up our speed suddenly increased (miraclous ey?) then of course it died 2 days later back down to 1MB. Have rung up 8 times now and nothings chnaged. This has also come along with constants disconnects, by constant i mean every 5 minutes. Have had 3 engineers out. Got a 'senior' engineer coming this week.  The guys on the phone said they would reset our profile over the weekend, as per normal absolutely nothings happened.
Heres my line stats.
ADSL Line Status
Connection information
Line state: Connected
Connection time: 0 day, 00:01:30
Downstream: 1,141 Kbps
Upstream: 444 Kbps
ADSL settings
VPI/VCI: 0/38
Type: PPPoA
Modulation: G.992.5 Annex A
Latency type: Interleaved
Noise margin (Down/Up): 5.1 dB / 22.6 dB
Line attenuation (Down/Up): 55.5 dB / 30.5 dB
Output power (Down/Up): 0.0 dBm / 12.8 dBm
FEC Events (Down/Up): 3917 / 0
CRC Events (Down/Up): 3 / 0
Loss of Framing (Local/Remote): 0 / 1
Loss of Signal (Local/Remote): 1 / 1
Loss of Power (Local/Remote): 0 / 0
Loss of Link (Remote): 0
HEC Errors (Down/Up): 163 / 0
Error Seconds (Local/Remote): 0 / 0
9 REPLIES 9
Message 2 of 10
Re: Constants Disconnects and Massive Speed Issues
resetting your profile won't help as profile is determined by your connection speed.  so you need a higher speed to get a higher profile.
with your 55 attenaution you could on a good connection get about 4mb
are you connected to the master or test socket? do you have other sockets apart from the master?
can you run btspeedtester and post the results
bredbin
Newbie
Message 3 of 10
We are connected to the master socket, no other sockets are in use as we are students so don't use the phone line.
Heres the speed test, not sure what happened to the upload but to be honest i don't care about upload.
Test1 comprises of two tests
1. Best Effort Test: -provides background information.
Download Speed
731 Kbps
0 Kbps 1000 Kbps
Max Achievable Speed
Download speedachieved during the test was - 731 Kbps
For your connection, the acceptable range of speeds is 400-1000 Kbps.
Additional Information:
Your DSL Connection Rate :1150 Kbps(DOWN-STREAM), 444 Kbps(UP-STREAM)
IP Profile for your line is - 1014 Kbps
2. Upstream Test: -provides background information.
Upload Speed
0 Kbps
0 Kbps 444 Kbps
>Upload speed achieved during the test was - 0 Kbps
Upstream Rate IP profile on your line is - 444 Kbps
Message 4 of 10
from what you say does that mean you do have other sockets just they are not in use?  if that is correct then can you connect to the test socket behind bottom half of master NTE5.
the good thing is you are on the new profile system so any increase in speed will be immediately reflected in a riae in profile and knock on rise in download speed
bredbin
Newbie
Message 5 of 10
Didn't know what a NTE5 was so had a Google search and have just realised that we are plugged into the test socket like you say.
Message 6 of 10
then try the quiet line test  dial 17070 option2  should hear nothing and best with a corded phone  if cordless then dull hum is normal
the call is free
bredbin
Newbie
Message 7 of 10
As were students we don't actually have a phone in the house so not sure how i would go about that.
Message 8 of 10
borrow a phone just for the test  just trying to make sure there is no noise on your line as this will kill your broadband
bredbin
Newbie
Message 9 of 10
Sorry i found a phone, did the test and there was no noise.
Message 10 of 10
then contact the mods for assistance  http://bt.custhelp.com/app/contact_email/c/4951
can take 2/3 days for mods to contact you
