Message 11 of 15
Re: Contention within BT FTTP Network?
I'm actually sad and disappointed by your response, as you have provided so much value to this forum in recent years.
1. I don't know if the available bandwidth on FTTP is 2.5GB, but I have this on good faith. My post suggests that there is a 10GB solution in the future using Nokia technology as posted.
2. My original post asked about contention on the 2.5GB GPON network, not 'how a hardware change will allow a 2.5Gb network to be able to provide a 10Gb synchronous connection with no additional fibre.'
I just want to understand the technical details.
Happy to continue his discussion....
Message 12 of 15
OK to understand it we have to go back. and look at arcitecture of the network and realise there is a relation between a fibre and the hardware used to supply a connection. As an ex VM customer I assume you know the differences  between EuroDOCSIS 2.0, 2.1, 3.0 and 3.1. (different hardware for increased speeds).
As each hardward comes along it expands the bandwidth of the existing network with VM it was more complicted due to the tech involved, multiple node splits etc. It was all hardware related.
Similarly with openreach using GPON bandwith expansion was achieved via hardware changes, initially at 2.5Gb per fibre up to 10Gb per fibre asynchronistaclly. They have been there for about the last 2 yrs, this is how Openreach can offer 1Gb connections to ISP's presently.
What the Nokia hardware you've referred to is the ability to offer 10Gb synchronous connections with a hardware upgrade.
Back in 2014 it was proved possible  to transmit 43Tb/s over a single fibre. Article HERE
Where I think you are becoming confused is the difference between synchronous and asynchronous. Asynchronus gives a lower upload speed to download speed ratio which is what Openreach is using at present for retail connections. The new Nokia hardware will lift that where they will now be able to allow a synchronous (i.e. equal up/down)  connection.
Message 13 of 15
Thanks pippincp,
I think what was missing for me was the usual 'news articles' that we normally see from BT indicating an upgrade from 2.5 to 10Gb  at some point over the past few years, as there is a lot of legacy information, but the truth is often hard to find!
On the plus side my address went live in the Openreach tracker for FTTP today, so I've finally been able to place an upgrade order for FTTP.
Fingers crossed, I may be about to reenter the 21st Century!
Thanks again
Message 14 of 15
Message 15 of 15
Adtran has just joined the list of contractors Openreach already has.
