davidmridge61
Expert
Message 1 of 16
Contract Termination
Once I am out of contract with BT, can I change service provider or do I need to provide any form of notice period?
15 REPLIES 15
john46
Message 2 of 16
Re: Contract Termination
you still need to give notice
davidmridge61
Expert
Message 3 of 16
If my contract expires on 28th July, can I provide 31 days notice on 28th June?
john46
Message 4 of 16
Yes if you wish to leave if moving to another provider however all you need is a MAC code
imjolly
Message 5 of 16
I think it is only 14 days if you use mac code
tiggs2
Message 6 of 16
not sure when my contract ends
hi i took   a contract   out with BT in May last year 2015 and I am not sure if it was for 12 monthes or longer  it was  for broadband, calls and BT sports ( which was free but soon after i had to pay)
I have had many problems so I will be leaving , so  where in MYBT could I find this info? thanks tiggs
Keith_Beddoe
Message 7 of 16
Re: not sure when my contract ends
If you would like to try Live Chat they should be able to help you.
Soon-Steve-Soon
Message 8 of 16
 Two "distinguished sage" both quoting the use of MAC,MAC have not been needed since late June 2015, all migrations are now Gaining Provider Lead where the new supplier does all the legwork in arranging the switch.
Time taken is still around 14 days.
umpire
Distinguished Guru
Message 9 of 16
@Soon-Steve-Soon,
If you had looked at the message dates you would have seen that the posts from the distinguished sages you refer to were from April 2015 before the new rules came in. 🙂
StewM
Distinguished Guru
Message 10 of 16
They would have to get up a bit earlier to catch you out hey Umpire!
Stew
