TheOldWiseMan
Message 1 of 5
Could my speed be better?
I live about 1km from my exchange (MYHSM) and it is 21CN WBC enabled. About 5 months ago it was just ADSL MAX and I would get about 6.5Mb/s. It is now showing G.992.5 Annex A and I'm getting a shade over 10Mb/s. I just feel that I should be getting a little bit more. Based on my stats below does my speed seem reasonble or is there headroom to squeeze more out?
ADSL Line Status
Connection Information
Line state: Connected
Connection time: 8 days, 08:12:57
Downstream:  10.15 Mbps
Upstream:  1.117 Mbps
ADSL Settings
VPI/VCI: 0/38
Type: PPPoA
Modulation: G.992.5 Annex A
Latency type: Fast
Noise margin (Down/Up): 7.8 dB / 6.0 dB
Line attenuation (Down/Up): 30.1 dB / 16.3 dB
Output power (Down/Up): 20.4 dBm / 12.6 dBm
FEC Events (Down/Up): 0 / 0
CRC Events (Down/Up): 13331 / 947
Loss of Framing (Local/Remote): 0 / 0
Loss of Signal (Local/Remote): 0 / 0
Loss of Power (Local/Remote): 0 / 0
HEC Events (Down/Up): 56142 / 655
Error Seconds (Local/Remote): 11929 / 593
4 REPLIES 4
imjolly
Message 2 of 5
Re: Could my speed be better?
with your attenuation and a good line I would hope for about 15mb
TheOldWiseMan
Message 3 of 5
It is the socket in the hall that I have put a BT Broadband Accelerator on and from that through a filter and a 5m reasonable quality cable to my HomeHub3. I'll whip the cover off when I get home and if it has a test socket I could try the filter directly in to the test socket tonight. I take it I wouldn't see an immediate speed increase, would it increase over time if it was going to increase?
Thanks for the quick response.
Regards
imjolly
Message 4 of 5
connecting to test socket may give an immediate increase but possibly hampered by the telephone extension cable which are normally not good news for broadband.  would be better with either a longer shielded modem cable from filter to hub or a longer ethernet cable from hub to pc
john46
Message 5 of 5
you should get some increase immediately you connect to the test socket do you have any extensions if not then the accelerator is not needed
