Stuo74
Message 1 of 13
Countless drops HH4...miraculous fix
Good evening, my broadband went into melt down a week or so ago, drops every 0, 5, 10, 15 mins. Incidentally this coincided with some contractors working for BT reasonably near my property. However, without anything being done my connection seems to have stabilised in the last day or so although the speed is down a bit and the downstream noisemargin up ( 9db was 6db) I have an engineer coming on Monday but was thinking maybe I should cancel for the fear of a £129 charge. Should I sit it out and wait for the DLM to do its thing? Thanks in advance
12 REPLIES 12
john46
Message 2 of 13
Re: Countless drops HH4...miraculous fix
yes I would cancel and let the DLM do its job just keep an eye on the connections stability
Stuo74
Message 3 of 13
Thank you. Law of sod says the drops will start again when I cancel!
Will the DLM lower the noise margin or am I going to have to pester customer services!?
john46
Message 4 of 13
given time and a stable connections the DLM will reduce the noise margin automatically
Stuo74
Message 5 of 13
Ok, cheers. I'll keep my eye on everything and with a bit of luck all will be well. The engineer is due Monday morning so I'll wait until Sunday before cancelling just in case
Stuo74
Message 6 of 13
Here we go again!!
<p>Hi, posted yesterday about my broadband seemingly stabilising albeit with a high downstream noise margin. I was going to cancel the engineer but fortunately didn't. Openreach have been working over the road, not next to my cabinet and wondered could it be whatever they're on with that's causing my issues!? Here's a snapshot of what is happening</p>
<p><img src="/t5/image/serverpage/image-id/49620iFF5327182B5C9D53/image-size/original?v=1.0&amp;px=-1" border="0" alt="IMG_1955.PNG" title="IMG_1955.PNG"></p>
Stuo74
Message 7 of 13
Re: Here we go again!!
I'll try that again!!
( 4576.580000) DSL noise margin: 6.30 dB upstream, 13.40 dB downstream
21:06:14, 21 Apr. ( 4575.670000) DSL line rate: 308 Kbps upstream, 8092 Kbps downstream
21:05:59, 21 Apr. ( 4560.700000) CWMP: session closed due to error: Could not resolve host
21:05:59, 21 Apr. ( 4560.680000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
21:05:59, 21 Apr. ( 4560.670000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE'
21:05:37, 21 Apr. ( 4538.600000) Admin login successful by 192.168.1.65 on HTTP
21:05:28, 21 Apr. ( 4530.110000) CWMP: session closed due to error: Could not resolve host
21:05:28, 21 Apr. ( 4529.770000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
21:05:28, 21 Apr. ( 4529.770000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE'
21:05:27, 21 Apr. ( 4529.200000) CWMP: Initializing transaction for event code 4 VALUE CHANGE
21:05:26, 21 Apr. ( 4527.830000) DSL is down after 7 minutes uptime
21:05:26, 21 Apr. ( 4527.830000) ETHoA is down after 7 minutes uptime
21:05:25, 21 Apr. ( 4527.420000) PPPoA is down after 6 minutes uptime [Waiting for Underlying Connection (WAN DSL -​ Up)]
21:05:21, 21 Apr. ( 4523.330000) PPP LCP Send Termination Request [User request]
21:04:31, 21 Apr. ( 4473.250000) New GUI session from IP 192.168.1.65
21:04:26, 21 Apr. IN: BLOCK [9] Packet invalid in connection (Invalid tcp flags for current tcp state: TCP [52.80.18.184]:443-​>[86.163.19.108]:50241 on ppp0)
21:01:49, 21 Apr. OUT: BLOCK [9] Packet invalid in connection (tcp reset attack is suspected: TCP [86.163.19.108]:43376-​>[64.186.176.170]:443 on ppp0)
21:01:02, 21 Apr. OUT: BLOCK [65] First packet is Invalid (Invalid tcp flags for current tcp state: TCP [192.168.1.65]:50228-​>[114.112.93.8]:80 on ppp0)
21:00:24, 21 Apr. IN: BLOCK [9] Packet invalid in connection (Invalid tcp flags for current tcp state: TCP [183.2.219.202]:80-​>[86.163.19.108]:50193 on ppp0)
20:58:51, 21 Apr. ( 4133.240000) CWMP: session completed successfully
20:58:51, 21 Apr. ( 4133.030000) CWMP: HTTP authentication success from https://pbthdm.bt.mo
20:58:44, 21 Apr. ( 4125.580000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
20:58:44, 21 Apr. ( 4125.570000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE'
20:58:33, 21 Apr. ( 4114.700000) PPP IPCP Receive Configuration ACK
20:58:32, 21 Apr. ( 4114.150000) PPP IPCP Send Configuration Request
20:58:32, 21 Apr. ( 4114.150000) PPP IPCP Receive Configuration NAK
20:58:31, 21 Apr. ( 4112.710000) PPP IPCP Send Configuration ACK
20:58:31, 21 Apr. ( 4112.710000) PPP IPCP Receive Configuration Request
20:58:30, 21 Apr. ( 4111.890000) PPP IPCP Send Configuration Request
20:58:30, 21 Apr. ( 4111.890000) WAN operating mode is DSL
20:58:30, 21 Apr. ( 4111.890000) Last WAN operating mode was DSL
20:58:28, 21 Apr. ( 4110.170000) PPPoA is up -​ VPI: 0, VCI:38
20:58:28, 21 Apr. ( 4110.150000) CHAP authentication successful
20:58:28, 21 Apr. ( 4109.880000) CHAP Receive Challenge
20:58:28, 21 Apr. ( 4109.880000) Starting CHAP authentication with peer
20:58:28, 21 Apr. ( 4109.880000) PPP LCP Receive Configuration ACK
20:58:28, 21 Apr. ( 4109.870000) PPP LCP Send Configuration Request
20:58:28, 21 Apr. ( 4109.870000) PPP LCP Receive Configuration Reject
20:58:28, 21 Apr. ( 4109.870000) PPP LCP Send Configuration ACK
20:58:28, 21 Apr. ( 4109.870000) PPP LCP Receive Configuration Request
20:58:27, 21 Apr. ( 4109.490000) PPP LCP Send Configuration Request
20:58:24, 21 Apr. ( 4106.130000) ETHoA is up -​ VPI: 0, VCI:35
20:58:24, 21 Apr. ( 4106.130000) DSL is up
20:58:23, 21 Apr. ( 4104.770000) DSL noise margin: 5.80 dB upstream, 9.00 dB downstream
20:58:22, 21 Apr. ( 4103.860000) DSL line rate: 1084 Kbps upstream, 10565 Kbps downstream
20:58:07, 21 Apr. ( 4088.720000) CWMP: session closed due to error: Could not resolve host
20:58:07, 21 Apr. ( 4088.700000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
20:58:07, 21 Apr. ( 4088.690000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE'
20:57:36, 21 Apr. ( 4058.130000) CWMP: session closed due to error: Could not resolve host
20:57:36, 21 Apr. ( 4057.920000) CWMP: Initializing transaction for event code 4 VALUE CHANGE
20:57:35, 21 Apr. ( 4056.500000) DSL is down after 0 minutes uptime
20:57:35, 21 Apr. ( 4056.500000) ETHoA is down after 0 minutes uptime
20:57:34, 21 Apr. ( 4056.090000) PPPoA is down after 0 minutes uptime [Waiting for Underlying Connection (WAN DSL -​ Up)]
Keith_Beddoe
Message 8 of 13
Is there any noise on your phone calls? Dial 17070 and select option 2, there should be no noise between the announcements.
Stuo74
Message 9 of 13
Is that a with a corded phone, I don't have one. However, when the issues first started BT sent a line engineer "by accident" he found no fault with the line
Keith_Beddoe
Message 10 of 13
