Message 31 of 39
Re: Court case forces Openreach to turn off Dynamic Line Management
can i change my profile? i mean interleaved or non interleaved, are you refering to 17a etc. ?
Distinguished Guru
Message 32 of 39
The 3 DLM profiles are speed, standard and stable
If not, I'll try again 🙂
Expert
Message 33 of 39
Where does it state what profiles we as infinity customers are on?
Distinguished Guru
Message 34 of 39
Probably on the order to openreach
Recognised Expert
Message 35 of 39
For reference the Digital Region Network never used DLM on any of it's connections - latency used to be with 5-10ms which was a lot better than you get with BT - any changes to the line were all done manually, so even if you were constantly disconnecting on a regular basis you could have still be getting the maximum speed you synced at.
I've also noticed over the past month speeds have been dropping with BT - and previously easily obtained 73-75Mbps and now only getting upto 69Mbps - Not sure if this due to work they have been doing recently but new cabs have gone up in our area.
There are good and bad points for having DLM or not....
Expert
Message 36 of 39
I still see may people complaining that DLM is affecting their connections.
So has DLM been turned off or not ?
Best regards,
dfenceman
Message 37 of 39
wrong thread
Message 38 of 39
DLM is on, I've had 2 line speed changes in the past 12 days.
Expert
Message 39 of 39
Can any of the CL's or mods answer if DLM is still active or not please ?
Best regards,
dfenceman
