Hi there
I was wondering if someone could reset my connection at the DLM to 6db. Recent problems with roadworks etc but very stable now. Below are my Routerstats SNR graphs for the last 3 days, DSL Uptime is at the bottom.
Thanks in advance
Solved! Go to Solution.
can you post your stats from your router
Sure, here you go...
I have mods to help with noise margin and they will post here
have you checked to see if exchange has been upgraded to adsl2? http://dslchecker.bt.com/adsl/adslchecker.welcome
Thanks for your help
Yes we're on ADSL2+
Hi @Daaave send over your details and we'll take a look. You'll find the 'click here to contact the mods' link in my forum profile.
Neil
Yes we're on ADSL2+
not according to your stats which are adslmax
Sorry I meant that ADSL2+ is available at the exchange. I am a long way from the exchange though.
enter your phone number in link I posted previously and then post results remember remove number
it may be mods can help get you upgraded to adsl2/2+
I got the reset done, thanks to everyone.
