Message 1 of 15
DLM Reset Issues - Advice Needed
Hi all,
Looking for some advice regarding DLM on Infinity 2 line. I had the DLM reset on the line as a few power cycles by myself had knocked me onto a lower IP profile and enabled interleaving, essentially doubling my ping times (dreadful for online gaming). My fault I know, but I wasn't aware of the pain that is DLM coming from ADSL fastpath to FTTC. Before that, I had 2 months of great speeds and ping times. DLM reset was done by engineer Friday 13/05/16 and all looked great - back onto high sync speeds and nice low pings.
Waking up this morning however, I see that the Hub has dropped connection overnight, sometime around 5am. Is this DLM again? Does DLM actually drop the connection if it makes a change? There doesn't appear to be any drop in sync and interleaving doesn't appear to be on. I will post logs below, as well as general stats (I believe the line drop event begins with the 5:12:12 PPP LCP Receive Termination Request (NONE) event). Also worth mentioning probably that I'm only 400m from exchange, according to the engineer. My concern is that DLM is going to continually drop the connection and I'm going to end up with interleaving back on in the near future. Any help greatly appreciated.
1. Product Name: HomeHub5
2. Serial number: +076286+1549002260
3. Firmware version: v0.07.05.0A13-BT (Type B) Last updated 10/3/2016
4. Board version: 01
5. VDSL uptime: 0 days, 09:29:29
6. Data Rate: 20000 / 79987
7. Maximum Data Rate: 27919 / 87568
8. Noise Margin: 10.0 / 8.1
9. Line Attenuation: 14.5 / 15.7
10. Signal Attenuation: 0.0 / 0.0
11. Data sent/received: 16.2 MB / 133.6 MB
12. Broadband username: bthomehub@btbroadband.com
13. BT Wi-fi: Yes
14. 2.4GHz wireless network/SSID: BTHub5-FPZR
15. 2.4GHz wireless connections: Enabled (802.11 b/g/n (up to 144 Mb/s))
16. 2.4GHz wireless security: WPA2 Only (Recommended)
17. 2.4GHz wireless channel: Automatic (Smart Wireless)
18. 5GHz wireless network/SSID: BTHub5-FPZR
19. 5GHz wireless connections: Enabled (802.11 a/n/ac (up to 1300 Mb/s))
20. 5GHz wireless security: WPA2 Only (Recommended)
21. 5GHz wireless channel: Automatic (Smart Wireless)
22. Firewall: Default
23. MAC Address: a8:d3:f7:75:e4:c3
24. Software variant: -
25. Boot loader: 0.5.1-BT (Wed Nov 12 11:52:05 2014)
05:16:50, 15 May.Device Connected: 192.168.1.221, c4:3a:be:96:c1:37, android-abbfe6cb527788fc
05:13:10, 15 May.CWMP: HDM socket closed successfully.
05:13:10, 15 May.CWMP: HTTP authentication success from pbthdm.x.x.x
05:13:10, 15 May.CWMP: HDM socket opened successfully.
05:13:09, 15 May.CWMP: session completed successfully
05:13:09, 15 May.CWMP: HDM socket closed successfully.
05:13:09, 15 May.CWMP: HTTP authentication success from pbthdm.x.x.x
05:13:09, 15 May.CWMP: HDM socket opened successfully.
05:13:08, 15 May.CWMP: HDM socket opened successfully.
05:13:07, 15 May.CWMP: Server URL: https://pbthdm.x.x.x; Connecting as user: ACS username
05:13:07, 15 May.CWMP: Session start now, server: pbthdm.x.x.x, Event code:
05:13:06, 15 May.CWMP: Initializing transaction for event code 4 VALUE CHANGE
05:12:43, 15 May.NTP synchronization success
05:12:29, 15 May.NTP synchronization start
05:12:28, 15 May.WAN connection PTM connected
05:12:27, 15 May.PPP IPCP Receive Configuration ACK
05:12:27, 15 May.PPP IPCP Send Configuration Request
05:12:27, 15 May.PPP IPCP Receive Configuration NAK
05:12:27, 15 May.PPP IPCP Send Configuration ACK
05:12:27, 15 May.PPP IPCP Receive Configuration Request
05:12:26, 15 May.PPP CHAP Receive success : authentication successful
05:12:26, 15 May.PPP CHAP Receive Challenge
05:12:26, 15 May.PPP LCP Receive Configuration ACK
05:12:26, 15 May.PPP LCP Send Configuration ACK
05:12:26, 15 May.PPP LCP Receive Configuration Request
05:12:26, 15 May.PPP LCP Send Configuration Request
05:12:17, 15 May.WAN connection PTM disconnected
05:12:13, 15 May.PPP LCP Send Termination ACK
05:12:12, 15 May.PPP LCP Receive Termination Request (NONE)
05:08:25, 15 May.Device Disconnected: 192.168.1.204, cc:4e:ec:eb:f8:b4, unknown
05:08:17, 15 May.Device Disconnected: 192.168.1.221, c4:3a:be:96:c1:37, android-abbfe6cb527788fc
04:58:15, 15 May.Device Connected: 192.168.1.221, c4:3a:be:96:c1:37, android-abbfe6cb527788fc
14 REPLIES 14
Message 2 of 15
Re: DLM Reset Issues - Advice Needed
DLM may disconnect you but I would not worry
Looks like your speed is as good as it can be and GINP is off. This if your cabinet supports it is applied before GINP
Just let it go and stop worrying
Message 3 of 15
Sorry i meant GINP is applied before interleaving
Message 4 of 15
Where do you see G.INP on/off in the stats/logs? Sounds like something else to look out for going forward.
Message 5 of 15
You dont have it you are at max 79987 and your profile is fully open
If GINP was on rate would show as 77.34 in the wholesale sleedtest
Message 6 of 15
Cheers for the input. What is the PPP LCP Receive Termination Request (NONE) event though? What has actually caused the line to drop? From my POV the line has been stable with no issues since the reset, but something has caused it to drop at 5am this morning.
Message 7 of 15
That is the network telling the router to disconnect and reconnect. It doesnt count towards DLM penalties
No idea why is doing it just leave it alone
Expert
Message 8 of 15
Hi
Its just the usual cpe wan management protocol doing its thing.
Ditch the hub and the TR-069 update issues will disappear..:)
Message 9 of 15
Excuse my ignorance Barry, but what's the TR-069 update issues? If I am to ditch the hub, what would you recommend having in its place? Everyone I've spoken to at BT seems to think I should be having uptime of weeks and months.
Message 10 of 15
you can buy a separate modem from auction and use the HH5 which many find a good solution or aternatively get a 3rd party mode/router like tplink 9980
