imjolly
Message 31 of 54
Re: DLM Reset
as I said already that you should go back to the tech who got you out of the banded profile and get him to fix the up speed as I doubt even if you can get a stable conenction that up speed will improve with manual assistance
Wref
Message 32 of 54
Re: DLM Reset
Thank you BT, crucial changes have been made and my upstream is now set back on to the optimum.
And to give credit where it’s due BT have also tried to speed up my downstream, although I personally think that the downstream numbers are perhaps a little bit optimistic.
I will continue to monitor my connection for the next few days, but I’m really thinking that the downstream would be much happier with the lowest available setting of interleaving and a target signal to noise ratio of 6dB.
Undoubtedly a step in the right direction though. Thank you very much once again.
Tags (2)
imjolly
Message 33 of 54
Re: DLM Reset
stats look really good with connection speed virtually at attainable speed and down margin at 3db giving that bit nore speed  now really hope the line stays stable and no drops resulting in interleaving then higher noise margin and lower speed   just need to keep monitoring
Wref
Message 34 of 54
Re: DLM Reset
Thanks for all of the replies buddy.
It’s actually looking pretty good at the moment as the latest connection analytics clearly show.
The recent changes that BT have made has resulted in a vast improvement, so kudos to them for that.
Thank you very much British Telecommunications...Buzby would be proud.
C5D14AF2-C1B6-4319-817A-8FB60F9D2C89.jpegD347E430-EE11-4910-A5DE-22DBEC4CB34E.jpeg7A782D9B-4753-4E35-9A98-F27F6633F6ED.jpegA76B34EC-4C17-457D-AD48-0609AB567FA0.jpeg
Tags (2)
imjolly
Message 35 of 54
Re: DLM Reset
Wref
Message 36 of 54
Re: DLM Reset
Yeah let’s hope so, and to give a little more credit where it’s due...A few more screenies that help to show the overall line statistics picture.
81771B5A-EB8E-4A45-9F35-DA2BD1CB3EDF.jpegCE6874C3-AF1D-4E26-B120-7DDAE23DB255.jpeg8FEEA882-3631-47FB-9D10-037E5CBBB467.jpegC4B7C4CD-E450-4827-BA2F-9DE3E0CA601E.jpeg
Tags (2)
Wref
Message 37 of 54
Re: DLM Reset
If I had just one more thing to say...lulz.
BToR Green Cabinet 175 (Exeter, Devon) desperately needs a FTTC upgrade, FTTP would be even better haha.
Only 7 remaining steps left on my Metropolitan/City Centre journey to BT Superfast Fibre...
I’d settle for Annex M aka ADSL2+M in the meantime. But that’s never widely available either, I only ever had it once, on a Plusnet (BT Group) business line.
Tags (2)
Wref
Message 38 of 54
Re: DLM Reset
Oh dear...so here we go again.
Sorry it’s official, BT’s technical support team are absolutely diabolical. What a total waste of my time.
I just asked for a referral link to write a BT customer review for Trustpilot and she didn’t even know what it was...lulz.
Tags (2)
Wref
Message 39 of 54
Re: DLM Reset
Knowledge is power so they say. Let’s look at a few facts...
Approximate connection drops for the month of August that were supplied to me by a BT support agent representative:
_______
• 24th = 55
• 25th = 77
• 26th = 64
• 27th = 35
• 28th = 66
• 29th = 10
• 30th = 20
• 31st = 40
_______
So...just over those 8 confirmed days that’s 367 connection drops with a current average of 46 drops per day.
I’m starting to think that the best thing about BT...will be leaving them.
_______
Tags (2)
imjolly
Message 40 of 54
Re: DLM Reset
with that many drops in connection you must be in banded profile with a rock bottom connection speed  can you post current router stats
any noise on quiet line test?  looks like you need an engineer visit
unless you move to virgin cable then it will be the same line from exchange to your home with the same problems with another ISP using openreach lines
