pippincp
Message 11 of 13
Re: DLM
I concur with @Webby obviously a reporting error from the Openreach modem. As you are within range then most likely crosstalk has caused it and until such time that Openreach decide to deploy vectoring there's nothing you can do.
Deathtrap3000
Recognised Expert
Message 12 of 13
Re: DLM
Your speed isnt going anywhere without some network intervention. But I doubt you will get anyone to look into it as your speeds are within the acceptable ranges.
mrgoldfish1
Message 13 of 13
Re: DLM
Thanks for your input everyone if anything changes stats wise I'll repost.
