Message 1 of 4
This is a question not a complaint.
For Months now I have been having broadband dropouts up to 200 per day which have caused DLM to perform its main function "stabilise" the line which drops the speed.
We had a visit from Openreach , long story short. I realised that the dropouts happened when it was raining and windy, he tested the external lines up and down the road and eventually discovered the problem, the line into the house was severely damaged where it went through a large tree to the extent that the outer covering was completely gone and the copper wires were exposed, result, problem now fixed.
He did an SNR reset. The download has been rock solid @6db but the upload is 28.5db this is causing my upload speeds to be much slower than they should be <> 300kbs and download is <> 12Mbps
Will DLM eventually sort this out, last time it took 5 weeks to get back to normal.
See Tech Log below
Product code:Smart Hub 2
Serial number:+091301+1846001579
Firmware version:v0.17.01.12312-BT
Firmware updated:Mon Jun 22 18:51:01 2020
Board version:R01
GUI version:1.56 15_02_2019
DSL uptime:2 days,09 Hours00 Mins40 Secs
Data rate:447 Kbps / 18.083 Mbps
Maximum data rate:1.248 Mbps / 18.244 Mbps
Noise margin:28.4 / 6.0
Line attenuation:12.6 / 21.5
Signal attenuation:12.5 / 29.4
VPI/VCI:0/38
Modulation:G.992.5(ADSL2+)
Latency type:Fast
Upstream error control:Off
Downstream error control:Off
Data sent / received:512.8 MB Uploaded  / 9.7 GB Downloaded
Broadband username:[email protected]
BT Wi-fi:Activated
2.4 GHz wireless network name:BT-ZZA67Q
2.4 GHz wireless channel:Smart (Channel11)
5 GHz wireless network name:BT-ZZA67Q
5 GHz wireless channel:Smart (Channel36)
Wireless security:WPA2 (Recommended)
Wireless mode:Mode 1
Firewall:On
MAC address:44:FE:3B:64:5C:68
Software variant:-
Boot loader:0.1.7-BT (Thu Nov 30 09:45:22 2017
Many Thanks
3 REPLIES 3
Message 2 of 4
Re: DLM
looks like your up speed is stuck.  if you can get 7 days stable and not change then post back and can see if mods can get up speed reset
Message 3 of 4
Re: DLM
Day 6 and DLM put me back to normal speed 17.7 down consistently and 1.1 up Noise margin: 8.2 / 2.9 No dropouts for 7 days.
Message 4 of 4
Re: DLM
Just maintain connection and it should drop noise margin further which will give increased speed
