Message 41 of 46
Re: DLNA - not working with HH3?
I have a HH3 type b and DLNA is hit and miss, sometimes it works sometimes it doesn't. Was all set to replace the router with an Asus RT-N65U/66U or a Netgear N900 but heard to 66U won't allow more than 200mbps using pppoe and I have a 330 Mbps FTTP line.
Now multicast and IPTV is coming I'm waiting again to see which is the best one to get. Would like to know how the HH4 is with DLNA as that is another possible upgrade.
Message 42 of 46
HH4 copes very well here
mellycoop
Message 43 of 46
My DLNA facility worked perfectly with 12 year old Orange hub but not working with new HH4 and when I spoke to BT Tech support they didn't appear to know anything about DLNA and are refusing to acknowledge that it is a problem with their HH4. Does anyone know if this issue has been resolved with firmware update or even if HH5 will resolve this?
theaceface
Message 44 of 46
The issue is not solved
I have the same problem since switching to BT and the HH4
It's stupid as my previous non BT set up worked fine with no issues
BT NEED TO ACT ON THIS ASAP!
theaceface
Message 45 of 46
Having just spoke to tech support it appears that HH4 will not work with DLNA and there are no plans for a firmware upgrade.
FunkMaster
Message 46 of 46
HH4 sucks .... now I am on the market for another router ... Thinking of the Draytek or Billion .... but *sigh*
