Message 1 of 7
DNLA media server with Home Hub 4
Hi - I've just switched to using the Home Hub that BT sent me and I can't seem to set it up as a media server. My old TP-Link router had an option to do this once a USB drive is plugged in. You could select which folders to share.
I plugged a USB drive into the Home Hub and I can see this as a network drive. Unfortunately, my Samsung Smart TV doesn't see anything. It used to see 'Media Server' and pick up my videos and music.
Any suggestions? I have UPnP enabled on the Home Hub, but I can't see any other settings that might help.
6 REPLIES 6
Message 2 of 7
Re: DNLA media server with Home Hub 4
Welcome to this user forum.
Do you still have your old TP-Link router? If you are on ADSL, there is nothing to stop you using it.
The USB port on the home hub is of very limited use.
Expert
Message 3 of 7
But was is the solution to the original post using the hh4?
Expert
Message 4 of 7
Stupid autocorrect. I meant what is the solution to the original post using the hh4?
Message 5 of 7
The USB port is mapped as SMB which many devices do not recognise.
Message 6 of 7
Sorry for being think, but does that mean the home hub can't act as DNLA server?
Message 7 of 7
*thick*, not 'think'!
