sonicm
Message 1 of 6
DNS Issues & Slowdown SmartHub
Hi,
I've noticed over the past month or so my internet download speed on unlimited has gone from 7.1meg-7.3meg to a static 5.5meg by the router doesn’t move, for the first year or so I had no issues but for some reason its slowed down almost to the point where I could get the slower deal (which is not what i want).
Also, I've noticed over the past few days that the DNS is stopping our Hive, WeMo & Hue devices from connecting. I've setup a temporary DNS service on my server at home to point to the google free DNS 8.8.8.8 and everything sprung back into life. Why oh why can't you update the DNS on the router! What a silly idea!
Mike
5 REPLIES 5
flamethrower
Message 2 of 6
Re: DNS Issues & Slowdown SmartHub
Hi Mike
Welcome to the forums. If you post your router stats, folk here might be able to comment on how healthy it looks:
https://community.bt.com/t5/Announcements-Guides-Community/Broadband-Top-Tips-to-get-help-on-the-for...
What router do you have?
Do you have PC/Mac? If so could you open a cmd window or terminal and try:
  nslookup www.bt.com
  nslookup www.google.com
and paste the output here.
P.
flamethrower
Message 3 of 6
A couple more thoughts:
1) if the nslookup's fail or are slow, try turning off Parental Controls to see if that affect's it. IIRC, BT's parental controls play games with DNS query interception and re-writing.
2) I'd guess BT don't allow updating the DNS servers because it opens the door to problems for their support. Customers who want this level of customizability will likely have their own router and not have BT support.
Cheers
sonicm
Message 4 of 6
Hi,
Thanks for the reply I've got the SmartHub and the technical details are as follows:
Product name: BT Hub 6A
Serial number:+084319+NQ71363217
Firmware version:SG4B1000B316
Firmware updated:19-Jul-2017
Board version:1.0
Gui version:1.64.0
DSL uptime:0 Days, 22 Hours 2 Minutes 32 Seconds
Data rate:14.05 Mbps / 55.00 Mbps
Maximum data rate:14063 / 65686
Noise margin:6.1 dB / 8.4 dB
Line attenuation:18.6 dB
Signal attenuation:
VPI / VCI:0/38
Modulation:G_993_2_ANNEX_B
Latency type:Fast Path
The lookup replies are:
Server: UnKnown
Address: 192.168.1.201
Address: 193.113.9.162
Server: UnKnown
Addresses: 2a00:1450:4009:80c::2004
172.217.23.4
I'm using windows 10 to access all of this.
Im not using parental controls
Many thanks
Mike
flamethrower
Message 5 of 6
Thanks Mike
The numbers look like they are in a reasonable ballpark to me, but I am not an expert on DSL stats so someone else may step in and say otherwise.
Does the router have Smart Setup enabled? If so, you might try disabling that and seeing if it makes a difference.
http://bt.custhelp.com/app/answers/detail/a_id/44328/~/what-is-smart-setup-on-the-bt-hub%3F-how-can-...
Best
P.
sonicm
Message 6 of 6
Hi
Thanks I can confirm smart setup is disabled.
