Message 51 of 56
Re: DNS Problem/Message stopping Kindle Fire 8 - Thought it was solved but problem back again
I've been using the Silk Browser since I stopped using BT Parental Controls and Web Protect, and have had no problems.
But as you need to use BT Parental Controls, maybe this update will do the trick - otherwise you may have to stay with Opera!!
Hope the update works for you. I will be very interested to hear how it goes.
Amazon try to be helpful, but it can be a bit of a merry-go-round.
Message 52 of 56
Silk working ok at the moment after update but based on past experience it is too early to say if it has been fixed. 😕
Message 53 of 56
The BT DNS blocking message has stayed away this evening so I'm hopeful that the latest kindle fire update has solved the problem and that all kindle fires will now work happily alongside BT parental controls. Fingers crossed! The End???
Message 54 of 56
My fingers are still crossed!!
Message 55 of 56
It's bad news I'm afraid, the problem is back!😠
Message 56 of 56
Sorry to hear that the update hasn't worked.
It's about time Amazon sorted this out.
