llme
Message 1 of 13
DNS hijacking
I'm unable to use OpenDNS or Google DNS servers because all requests to resolve google.com (or any google address I believe) are being hijacked and directed to a BT IP address (31.55.184.0/24):
Primary DNS: 208.67.222.222 (OpenDNS) or 8.8.8.8 (Google DNS)
tracert google.com
Tracing route to google.com [31.55.184.119] <- Incorrect BT IP address
BT default DNS:
tracert google.com
Tracing route to google.com [74.125.230.228] <- Correct Google IP address
I know you have just blocked a bunch of sites by court order but I think you have also broken something ..
Edit: Should add I just realised I have posted this to the wrong forum! I am an Infinity customer using a HH5
12 REPLIES 12
Keith_Beddoe
Message 2 of 13
Re: DNS hijacking
This is the correct behaviour, as BT have direct links into Google to give the best performance. To do this, DNS requests for any Google service are intercepted before they enter the core network, and redirected down very fast trunks.
llme
Message 3 of 13
Re: DNS hijacking
Ok I see .. that BT IP address is unreachable though
spidermike2010
Message 4 of 13
Re: DNS hijacking
That court order was pie in the sky. They've started blocking independently.
anthonyUK
Expert
Message 5 of 13
Re: DNS hijacking
Great another hidden 'benefit' that I don't want. Managed to get most things fixed but my Chromecast will not work.
It cannot connect to the internet (Google I guess) but everything else can.
floyduk
Message 6 of 13
Re: DNS hijacking
Is it also correct behaviour that those IP addresses BT is hijacking to aren't actually routable? Cause I'm having this same problem and it's stopping me accessing Google services.
ray_dorset
Distinguished Guru
Message 7 of 13
Re: DNS hijacking
This most certainly isn't "correct behaviour"
If not, I'll try again 🙂
floyduk
Message 8 of 13
Re: DNS hijacking
Silly question.
If BT is rewriting Google DNS and Open DNS results to give their own IPs that send traffic down super fast trunk routes then why wouldn't they also do the same rewriting for their own BT DNS server results?
llme
Message 9 of 13
Re: DNS hijacking
Completely agree. If BT want to redirect their own DNS server requests then fine, but they should not be doing this for non-BT DNS servers.
@floyduk wrote:
Silly question.
Good question.
anthonyUK
Expert
Message 10 of 13
Re: DNS hijacking
Good question.
That is the question. Why are BT not routing their own DNS results internally?
It doesn't make any sense and I hope it isn't anything nefarious.
